Cutting leg opening in passenger side forward bulkhead
GBR Dory
City/Region: Sitka
Vessel Name: Alacrity
Photos: Alacrity
PostPosted: Sat Feb 11, 2023 12:59 am    Post subject: Cutting leg opening in passenger side forward bulkhead Reply with quote
Hi All,
We have a 2004 22' Cruiser and have the old story of people want to sit facing forward. Our forward dinette bench does not move and I've epoxied a nice chart into the table. So, I don't want to modify the table and I've just retired the 19 year old Toyotomi heater that was mounted inside the v-berth.
I've seen a random photo of an older C-Dory with the bulkhead trimmed out but has anyone with a similar aged boat done this? My family like the idea of sitting on the forward bench with legs stretched out into the v-berth.
I am in the process of installing a diesel heater under the galley and adding ducting to the v-berth, windshields, and cabin in general. The forward bench cushion will be easily modified to fit whether facing forward or aft.
Thanks in advance
G
Greg G
22' Cruiser
Gene&Mary
City/Region: Seattle/Center Island
Vessel Name: Linnea
Photos: Linnea
PostPosted: Sat Feb 11, 2023 10:14 am    Post subject: Reply with quote
Go for it. Best mod I ever made. Helps for sleeping and access too.
GBR Dory
City/Region: Sitka
Photos: Alacrity
PostPosted: Sat Feb 11, 2023 12:32 pm    Post subject: Reply with quote
Thanks for having pictures in your album to see, it looks great and very open. I was just thinking of cutting a portion of the bulkhead (seat back) but leaving the dash.
PostPosted: Sat Feb 11, 2023 12:33 pm    Post subject: Re: Cutting leg opening in passenger side forward bulkhead Reply with quote
GBR Dory wrote:
Hi All,
Thanks in advance
G
A thing to consider is if the bulkhead is cut out, how will you sit facing the dinette? The bulkhead is the backrest for the forward dinette seat.
Personally, I prefer the enclosed v-berth. It is more private, cosy, and better for sleeping (IMO).
PostPosted: Sat Feb 11, 2023 5:28 pm    Post subject: Reply with quote
The bulkhead is no structural and can be removed. I would keep the shelf above for several reasons.
You can modify the seat back to rest against this upper shelf on the port side when sitting facing aft, and the same back should be able to be used on the forward facing position. But stilling for hours with legs straight out, may not be the most comfortable position....
Go for what you want.
txmntman
City/Region: GEORGETOWN
State or Province: TX
Vessel Name: Saint Somewhere
Photos: Saint Somewhere
PostPosted: Sun Feb 12, 2023 1:19 am    Post subject: Reply with quote
I have a 2006 CD22, and I made some mods to my boat after attending the Hontoon gathering last year. These include cutting out the bulkhead on the passenger side, while leaving the top shelf. I would be happy to discuss this mod with you, and there are pics in my album “changes after Hontoon 2022 gathering” (or close to that).
I would also be happy to tell you what I learned in making that mod (ie, take all you can out of the boat, because the dust during cutting gets into to EVERYTHING).
Good luck, and let us know how it came out!
CD 22 “Saint Somewhere” 2020 - Present
SeaSwirl 1850 Striper "Nicky" Sold
Alumicraft Sold
Boston Whaler Montauk "Joe Bob" Sold
Hobie Cat "Mikey Likes It" Sold
Gene&Mary
Vessel Name: Linnea
Photos: Linnea
PostPosted: Sun Feb 12, 2023 11:30 am    Post subject: Reply with quote
We removed the top shelf also. One of the many reasons to do this mod is to accommodate sleeping for taller folks. You do have to build a small "shelf" with a pad to extend the berth. Taking the top shelf out allows much better access and allows that sleeper to sit up.
You can reuse the black edge trim to trim the new cut edges.
GBR Dory
City/Region: Sitka
Photos: Alacrity
PostPosted: Tue Feb 21, 2023 9:26 pm    Post subject: Reply with quote
I got brave and made the cuts to the bulkhead! I hope the link goes to the photo, but it's in our boat album regardless now.
I'm still sorting out a support for the back cushion to be in either forward or aft position. I'm thinking about 2 Aluminum or stainless pieces of flat bar stock that will extend below the cushion and be attached via some belt loop type things.
It is too cold here now to fiberglass the edges so I am looking at a larger version of the black edging around the v-berth entrance.
I like the result so far.
http://www.c-brats.com/modules.php?set_albumName=Alacrity&id=IMG_6135&op=modload&name=gallery&file=index&include=view_photo.php
Page generation time: 0.0538s (PHP: 61% - SQL: 39%) - SQL queries: 21 - GZIP disabled - Debug on
