Li batteries and solar - video by Nigel Calder
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Mon Jan 09, 2023 12:18 pm    Post subject: Li batteries and solar - video by Nigel Calder Reply with quote
For anyone considering the addition of Li batteries and/or solar panels to their boat, I highly recommend this excellent 2022 video by Nigel Calder.
https://www.youtube.com/watch?v=-iUVHVik1jY
Paul
PostPosted: Mon Jan 09, 2023 1:37 pm    Post subject: Reply with quote
Thanks. Interesting video--brings up more questions than it answers, but does give a summary of the state of the battery industry. Not sure if much of this really applies directly--but certainly if you are sophisticated ref batteries and panels it gives a goo review.
nicklee
C-Dory Year: 1988
C-Dory Model: 22 Classic
PostPosted: Mon Aug 21, 2023 5:43 am    Post subject: Reply with quote
Thank you. I have a stupid question, the space on boat is very limited. How to install solar panels?
PostPosted: Mon Aug 21, 2023 1:06 pm    Post subject: Reply with quote
Take a look at my recent solar install in my nested album for C-Traveler. I think you may have already seen my thread on Basic Solar. This was on my 25. But would have worked on my previous 22 as well.
Colby
PostPosted: Mon Aug 21, 2023 1:48 pm    Post subject: Reply with quote
C Dory owners have used many different ways from fold up suit case panels, thru the flexible to the solid screwed down on the cabin top. There needs to be an air space under the panels. At least 200 watts is desirable if running any refrigeration.
Do you cruise long distance and time without any mains power or generator? If so then solar panels make sense. We never put them on the boat, instead carried one of the Honda Generators, 1000 or 2200.
Do you want to track the sun? or just lay flat and take a chance on how much you will need. Every boat with solar panels should be tracking battery state of charge, with device such as Victron Smart Shunt or 712 monitor. You want to measure volts, amps in and out, and state of charge.
Consider the latitude and potential cloud shading, Ambient temperatures are important. Type and size of battery and the controller is important. Some of the cheaper LiFePO4 are now competitive price wise with quality AMG batteries.
PostPosted: Mon Aug 21, 2023 5:13 pm    Post subject: Reply with quote
You also need to keep track of panel shading from parts of the boat. Some panels will significantly decrease output if any part of the panel is shaded (e.g. like from an antenna or mast).
Page generation time: 0.0358s (PHP: 52% - SQL: 48%) - SQL queries: 19 - GZIP disabled - Debug on
