C-80 problem
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Feb 25, 2006 7:42 pm    Post subject: C-80 problem Reply with quote
Just got back from an overnight in the San Juans. Yesterday I noticed than the speed window on the C-80 was registering about 2-3 MPH less that the speed on the Navman. Both get their input from NMEA. Then today on the way back the speed indication on the C80 went to 0. In looking at the wiring I discovered a wire hanging loose and have no idea where it was connected. It looks as though it came out of a crimp type connector. The wire is one of the wires that comes from the GPS Raystar 125 ant. The brown one. Which in the manual says it should go to RTCM in /+. I have no idea what that means and also can't find any wiring diagrams showing the wiring of the four or five different plugs that plug into the back of the C80.
What also baffles me is that I am still getting GPS SOG in MPH on the Navman.
Anyone have any thoughts or info on this?
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
sailor-d
Photos: Sailor-D
PostPosted: Sat Feb 25, 2006 8:05 pm    Post subject: Installation manuals Reply with quote
I don't have my C70 (C80 installation appears the same) yet but I have been downloading PDF's from Raymarine. I don't know which manuals come with the equipment but possibly their PDF manuals "C Series Display Installation Manual" document number 87020-2, April 2004 and the Raystar 125 manual on PDF may help - I am sure the latter is included with the Raystar 125. Regarding your Navman conflict I have no idea - not familiar with the equipment.
cheers - Dave
Sealife
City/Region: Woodland Hills
Vessel Name: SeaLife
Photos: SeaLife
PostPosted: Sat Feb 25, 2006 8:18 pm    Post subject: Reply with quote
David,
Don't know about the wire problem, but the SOG in mph can be changed to knts by going into the Memu, selecting, setup, units setup, speed units, Knots.
Mike - Sealife
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sat Feb 25, 2006 10:22 pm    Post subject: Reply with quote
David,
You could try calling the raymarine help line. They would probably be able to tell you exactly where that wire should be connected. They have helped me with my C80. \
Good Luck,
Steve
Alyssa Jean
PostPosted: Sat Feb 25, 2006 11:02 pm    Post subject: Reply with quote
Does anyone know what the (RTCM in /+) refers to
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Sat Feb 25, 2006 11:25 pm    Post subject: Reply with quote
This may help http://www.raymarine.com/raymarine/SubmittedFiles/Handbooks/Navigation/81247_3www.pdf
Pete
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Feb 25, 2006 11:26 pm    Post subject: Reply with quote
Yes that is a connection that is used when you utilize SEATALK.... the C80 can use NEMA or SEATALK.... the beauty of SEATALK is the ability to interface different inputs into one box... I don't think your C80 needs anymore than NEMA direct connections... in fact I don't think they package SEATALK boxes into the packages anymore. In the past the SL70 series Ramarine units used a GPS SEATALK connection.
Joel
SEA3PO
sailor-d
Photos: Sailor-D
PostPosted: Sat Feb 25, 2006 11:29 pm    Post subject: RTCM Reply with quote
The wiring connections appear to be detailed on pages 4 and 5 of the Raystar 125 installation manual. The term RTCM is a standard somewhat like NMEA. Am I stating the obvious or adding to the confusion?
cheers - Dave
Sea Skipper
City/Region: Bend, Oregon
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Sat Feb 25, 2006 11:49 pm    Post subject: Reply with quote
RTCM (Radio Technical Commission For Maritime Services) is used if you have an external DGPS receiver (Not likely). Most likely your GPS 125 is connect to the C-80 by a SeaTalk connection and the brown wire should be grounded - usually it would be crimped along with the shield wire in the same terminal. If you are using a NMEA connection, the green wire would also be connected to the shield wire. For Sea Talk the green wire goes with the red +12 volt wire. See manual @ http://www.raymarine.com/raymarine/SubmittedFiles/Handbooks/Navigation/81247_3www.pdf
Hank Brooks, Sea Skipper
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Sat Feb 25, 2006 11:50 pm    Post subject: Reply with quote
Here in my be your problem...note "RED" instructions:
NMEA sentences
Output sentences:
GPGGA, GPGSA, GPGSV, GPGLL, GPRMC, GPDTM, GPGNS, GPVTG, PRAYA
Input sentences:
PRAYI, PRAYE, PRAYA
Note: If the Brown (RTCM) and Green (NMEA in/+) wires are not used, they must be
suitably grounded.
Mike Taylor
330-936-1030
Alyssa Jean
PostPosted: Sun Feb 26, 2006 9:28 am    Post subject: Reply with quote
Thats it, the brown is grounded if not used. Thanks WhalerGoFar and Sea Skipper. I couldnot find the reference wiring diagrams with the notes that brn goes to ground.
Go out and fix it as soon as it gets light. And guess I will have to put her in the water today to see it all is okay.
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Sun Feb 26, 2006 9:55 am    Post subject: Reply with quote
David --
Trust your windshield wipers are working well for your morning cruise ...
Alyssa Jean
PostPosted: Sun Feb 26, 2006 10:59 am    Post subject: Reply with quote
Are you inferring that it rains in the NW? Actually the annual rainfall here in Anacortes is only about 30" a year. And to answer your question, my port wiper doesn't work worth beans. There is no tension from the blade to the window. It keeps coming loose where it is mounted with a set screw to the wiper motor shaft. Maybe need a new upper wiper blade assembly. Or maybe I can increase the spring tension on the blade arm.
El and Bill
Photos: Halcyon
PostPosted: Sun Feb 26, 2006 12:06 pm    Post subject: Reply with quote
Maybe you have a good excuse for a CR-21-EC?
Alyssa Jean
PostPosted: Sun Feb 26, 2006 4:50 pm    Post subject: Reply with quote
Okay, the no signal problem is fixed by re-grounding the loose wire. However there still is a differential in what the C80 shows for speed and what the Navman shows. They both get the same signal from the NMEA output from the ant. The Navman shows 3-4 MPH higher than the C80.
Could it be caused by not enough power input now that I am powering two units with the same input. A question for Les on Tues. if I can get him to answer the phone.
Page generation time: 0.0382s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
