kaelc
Vessel Name: Island Magic
Photos: Stil-Afloat
Posted: Thu Sep 30, 2021 11:19 pm Post subject: Davit for lifting |
Looking at the St Croix 488 rotating davit for mounting one on the gunnel for lifting a dingy onto the roof. I’ve found a set of 2 for sale and would use 1.
What does everyone think? Would it work?
https://www.davit.com/rotating.html |
jkidd
Joined: 23 Oct 2006 Posts: 1622 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Fri Oct 01, 2021 9:38 am Post subject: |
Those look like there made for the stern. Doesn't look like they would rotate far enough to put the dingy on the roof.
_________________ Jody Kidd
KE7WNG
Northern, Utah
kaelc
Photos: Stil-Afloat
Posted: Fri Oct 01, 2021 11:09 am Post subject: |
Thanks @jkidd what brand and model is yours? Looks great |
jkidd
NORO LIM
Photos: NORO LIM
Posted: Fri Oct 01, 2021 3:19 pm Post subject: |
If you type "garhauer" in the search box at the top of the page, you will find loads of information in various threads. _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
Posted: Fri Oct 01, 2021 7:47 pm Post subject: |
Here is a link to photos of the Garhauer Davit which I have put on 4 C Dorys. _________________ Bob Austin
Catskinner
C-Dory Year: 2022
Vessel Name: Dock Holiday
Photos: Dock Holiday
Posted: Sun Oct 10, 2021 1:39 pm Post subject: Garhauer davit |
Bob,
What did you come up with regarding optimum height for your davit? I’m trying to put 2 Hobie revo 13’s on the roof of my 26’ venture and then a 9’ dinghy on top of those.
Tia, CS |
Posted: Sun Oct 10, 2021 2:57 pm Post subject: Re: Garhauer davit |
Catskinner wrote: | Bob,
Tia, CS |
I used to own a 13 Revolution, and my current inflatable is a 9.5' air floor with 15" tubes. On our C Dory 25, we added 12" to the base tube. That was enough to get the boat just to the cabin top level--and then slide it up onto the top, with minimal weight on the cabin. I had been thinking about putting the spreader bar lower, and at the point of balance. (it is about 3" off, utilizing the D rings which were already in the boat.
Also we don't know if you are going to use a rack, or just some padding under the kayak directly on the roof structure.
I advise adding 24" for most boats. The problem is I don't know how "tall" Garhauer will make the lower support tube. I also don't know what point you will use to attach the Rev. to the spreader bar.
If Garhauer will allow 30", that is where I would be just eyeballing what is necessary.
Let us know how it works out. |
Catskinner
C-Dory Year: 2022
Posted: Sun Oct 10, 2021 3:21 pm Post subject: |
Thank you Bob! I think I’ll give them a ring next week and see what they will do. |
Catskinner
C-Dory Year: 2022
Posted: Mon Oct 11, 2021 8:00 pm Post subject: |
The answer was I’ll make whatever you want, if anyone is interested! |
pelkie123
Joined: 27 Oct 2012 Posts: 3384 City/Region: SW Michigan
Posted: Wed Dec 07, 2022 5:15 pm Post subject: Re: Here's a davit system that Ranger boats use: |
It is kind of a kludge IMO. You could do something similar on a C-Dory if you really wanted to. |
Posted: Wed Dec 07, 2022 6:52 pm Post subject: |
I had looked at that system, and my conclusion was that you needed two rather long swim steps, which went beyond the outboard. Would that be practical for the C Dory line? Also there is already a swim step/outboard bracket involved for the outboard. The mechanism is a but crude with the winch which has to be put on the gunnel etc. There would be easier and smoother ways to do that part of it using a small electric winch.
I had a system which pulled a 12 1/2' RIB with 25 hp (Weight in the 370# category) over the transom of my Cal 46, like a "pull boat" on a purse seiner, with an electric winch--smooth and about a minute to either retrieve or launch even when under way. That type of system might be developed as part of a frame, rack over the cockpit of the C Dory 22 or 25, instead of a Bimini. I know of some 22s which carry the dinghy on a rack over the cockpit--but I don't believe any of them are motorized. |
