Trim Tabs 22 Cruiseer
The Commodore
Photos: The Commodore
PostPosted: Mon Oct 24, 2022 11:02 am    Post subject: Trim Tabs 22 Cruiseer Reply with quote
I don't think my trim tabs are working. I purchased this 2007 22 Cruiser a couple of months ago and have been working my way through a variety of small issues. Trim tabs are next. When I press the rocker switches up or down nothing happens. I have no paperwork or manuals. How do these things work? Where do I begin troubleshooting? I've spotted a couple of inline fuses but have not opened them up.
Schuster
City/Region: Port Orchard
Vessel Name: Sea Witch
Photos: Sea Witch
PostPosted: Mon Oct 24, 2022 11:38 am    Post subject: Reply with quote
It sounds like you are on the right track. I would see if there is electrical to the switch first, then follow that by seeing if the power goes past the switch, if not then possibly a bad switch (rocker). Continue to follow the power down to the pump. If you have power to the pump then possibly the pump is frozen. Just eliminate possible causes as you continue to trouble shoot.
(Sea Witch)
25' Cruiser
The Commodore
PostPosted: Mon Oct 24, 2022 11:50 am    Post subject: Reply with quote
There's a pump somewhere? Back under the engine behind the fuel tanks?
CC Rider
City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
PostPosted: Mon Oct 24, 2022 12:32 pm    Post subject: Reply with quote
No, not if they are electric trim tabs.... Very Happy
MMSI#: 316033635
cbbernard
City/Region: Wakefield
State or Province: RI
Vessel Name: SEA STORY
PostPosted: Mon Oct 24, 2022 12:33 pm    Post subject: Reply with quote
Note that on my 22, the hydraulic trim tabs don't work unless the key is in the ignition and turned part way on.
PostPosted: Mon Oct 24, 2022 5:48 pm    Post subject: Reply with quote
If they are hydraulic, there will be a hydraulic oil reservoir, most likely in the stern somewhere. On my 22, they were electric. It's not unusual for the electric ones to eventually corrode and burn out if they get water in them. (I had that happen on mine). But would be more likely to only happen on one or the other, rather than both. If neither are working, and they are electric, I would bet more on a fuse. If hydraulic, could be a fuse, or the pump. I would definitely check any fuses in the circuit. Enjoyed meeting you out at Tenney Park. C-Traveler is all put away for the winter now. I have hydraulic tabs on it. I think I like them better than the electric... Colby
Page generation time: 0.0277s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
