back-upl ights on trailers? 5-prong plug
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Thu Oct 06, 2022 4:02 pm    Post subject: back-upl ights on trailers? 5-prong plug Reply with quote
Hey all,
I have new trailer for a 22' Cdory, with hydraulic surge brakes. It has a 5-prong plug, my tow vehicle has a 4-prong plug.
Am I correct in assuming the 5th prong is for back-up lights?
If so, do 22' trailers usually have back-up lights? (Previously I have only has a 16' trailer, 4-prong plug, no back-up lights)..
thanks!
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
PostPosted: Thu Oct 06, 2022 4:45 pm    Post subject: Reply with quote
Most boat trailers do not have backup lights. The vehicle backup light circuit is tapped to control the trailer backup solenoid. When the solenoid is on, the brakes on the trailer will not be applied when backing up (this would normally compress the surge cylinder and apply the trailer brakes). On some trailers you can manually disable the brakes for backing. Since that automatically resets when moving forward, moving the trailer back and forth (say getting into a tight parking spot) can be a PITA because you have to keep setting the bypass. Having an electrically controlled solenoid is more convenient.
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Thu Oct 06, 2022 8:05 pm    Post subject: Reply with quote
Ah, yes, of course!
Thanks for informing me..!
PostPosted: Thu Oct 06, 2022 8:51 pm    Post subject: Reply with quote
There are several ways of bypassing the surge brakes when backing. One is a hole thru the frame so the surge brakes would not apply. Also "Chain Vise Grips" can be locked around the frame. This way, you can back and fill all you want, with the brakes off.
Page generation time: 0.0822s (PHP: 20% - SQL: 80%) - SQL queries: 21 - GZIP disabled - Debug on
