Ken O
Joined: 05 Mar 2014 Posts: 112 City/Region: West Yellowstone
State or Province: MT
C-Dory Year: 1990
Vessel Name: Ravens' Roost
Photos: Ravens’ Roost
Posted: Wed Sep 28, 2022 2:01 pm Post subject: Lower unit bolts--thread locker vs. gasket sealant |
Time to replace the Honda BF90 impeller. Last time I just put Locktite blue on the bolts that attach the lower unit to the rest of the engine. So far I've only run the motor in fresh water, but there's salt water in the future. Several forums advocate some sort of gasket sealer on these bolts so they don't seize after sitting in salt water. The Honda manual specifies Locktite 271, which is the red stuff. Maybe the spec has changed, but I can't see using the permanent-need-a-torch-to-get-it-off stuff here.
My guess would be to go with Locktite blue again, but maybe there are better options. What has worked for people and what has not worked? Thanks! _________________ "If it were easy, everyone would be doing it." --Circumnavigator and author Larry Pardey. |
srbaum
Joined: 30 Aug 2010 Posts: 884 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Wed Sep 28, 2022 4:03 pm Post subject: |
Ken O,
I overhaul outboards for a hobby and have worked on every brand and size. I've got a least 10, that I am finishing up at this time.
After YEARS of failures and seeing corrosion from minor to major, my solution to ensuring that a fastener comes apart in the future is to use Tef-Gel on them. The stuff is expensive, but it really works and you only use small amounts. Tef-Gel forms a barrier, so that stainless to aluminum will not cause corrosion. Tef-Gel also prevent stainless steel fasteners from galling. With few exceptions, I use Tef-Gel on every fastener on outboards, trailers and most anything else that may see saltwater.
Additionally, larger surfaces, such as drive shafts, shift shafts, water pick up tube, prop shaft, etc, I coat with liberal amounts of Green Grease. Green Grease can be purchased at Napa or other auto stores. Green Grease is water proof and it is synthetic, so you can use it to coat your impeller before installing it, as well as use it to cover battery terminals, etc. Green Grease comes in a large grease gun size container, but it is very inexpensive. _________________ Steve Baum
Homeport of Portsmouth, VA
DayBreak
Joined: 16 Jul 2017 Posts: 858 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Joined: 27 Oct 2012 Posts: 3386 City/Region: SW Michigan
Posted: Wed Sep 28, 2022 5:38 pm Post subject: Re: Lower unit bolts--thread locker vs. gasket sealant |
Ken O wrote: | Time to replace the Honda BF90 impeller. Last time I just put Locktite blue on the bolts that attach the lower unit to the rest of the engine. So far I've only run the motor in fresh water, but there's salt water in the future. Several forums advocate some sort of gasket sealer on these bolts so they don't seize after sitting in salt water. The Honda manual specifies Locktite 271, which is the red stuff. Maybe the spec has changed, but I can't see using the permanent-need-a-torch-to-get-it-off stuff here.
My guess would be to go with Locktite blue again, but maybe there are better options. What has worked for people and what has not worked? Thanks! |
IME, Locktite Red is not permanent. Might take a little more umph than Blue but not that much more. Maybe on small screws it is stronger, but nothing you can put a wrench on. |
Ken O
C-Dory Year: 1990
Posted: Wed Sep 28, 2022 5:40 pm Post subject: |
Thanks a bunch for the thoughts. I have both Tef Gel and waterproof marine grease. My Tohatsu 9.8 kicker manual specifies Tef Gel for certain inner parts. I've had the same little tube for several years, so the cost isn't an issue. |
Posted: Wed Sep 28, 2022 9:58 pm Post subject: |
I've used red Locktite on my bikes for years so nothing would come apart. Which it did with blue Locktite. Never had a problem removing red coated screws; If you can get a wrench on them, they'll come out.
Boris |
