colored anti-skid deck
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Sun Feb 19, 2006 2:26 am    Post subject: colored anti-skid deck Reply with quote
I've noticed in a lot of photo's that many c-dory's have an accent color to their anti-skid (diamond pattern in gelcoat) surface. Mine doesn't have any color just gelcoat color. Also the surface seems a little porous and absorbs dirt. Did the factory quite coloring them?
PostPosted: Sun Feb 19, 2006 3:03 am    Post subject: Reply with quote
flapabreaker-
The non-skid on the topside decks is not real soft and rubbery, just somewhat softer and with the diamond pattern finish to increase adhesion. The fact that your boat has different absorbtion properties in the diamond patterened areas indicates that there is non-skid there.
Why is it the same color as the hull?
Your boat has a medium grey accent stripe. Since the grey is neutral (not red, green, yellow, blue, etc), the non-skid has to be neutral as well, as a real color would not fit with the grey. Thus your non-skid has to be either a lighter grey or the hull color to be a good, workable, and compatible color with the basic off white hull color and grey trim. This is according to standard art and interior/exterior design color theory.
I'm guessing that the factory has tried the different combinations possible over the years, and made yours with the non-skid the same as the basic hull color. If you think about it for awhile, you will probably come to the conclusion that they made the best choice possible.
My $0.02 guess!
Joe.
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Sun Feb 19, 2006 3:19 am    Post subject: Reply with quote
The factory can and will furnish the white non-skid (same color as the gelcoat) if it is ordered that way. Normally they will have a non-skid color which complements the accent color (not the same color as the accent). For example I have the Cabernet accent which would normally come with the light grey non-skid. I preferred to have the white non-skid, like the gel coat and they furnished it. Several other C-Dory owners have done the same and probably some of the dealers.
Pretty darn accomodating, them factory guys!
Enjoy!
Mark on Mighty Bite
Rabidfish
Dealer
City/Region: Noblesville, Indiana
State or Province: IN
Vessel Name: Les Poisson Enrage'
Photos: Rabidfish
PostPosted: Sun Feb 19, 2006 9:57 am    Post subject: Reply with quote
The "factory standard" color is white.
There is an option to color the non skid with either gray or tan.
It's available on any color boat...
The best things in life come on a stick!
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sun Feb 19, 2006 11:11 am    Post subject: Reply with quote
My dealer ordered the Moca/Wheat color scheme carried over onto the non skid as well, so I think one can order most anything.
Don
Page generation time: 0.0366s (PHP: 65% - SQL: 35%) - SQL queries: 18 - GZIP disabled - Debug on
