Overheating Outboard on Flushing Muffs
ATPNW
City/Region: Covington
Vessel Name: Fellowship
Photos: Fellowship
PostPosted: Thu Sep 08, 2022 11:19 am    Post subject: Overheating Outboard on Flushing Muffs Reply with quote
So I just got back from a week long outing at Sekiu. The twin BF50's are still running great. Upon getting home and flushing the port motor, the over heating alarm went off. I was in the cabin and was able to turn off the motor within a second or two. I had a helper out back of the boat who confirmed there was a stream of water coming from the tell tale (although it could have been a weak stream). I was able to get out of the boat, re-adjust the muffs and fired it back up with no more alarm the rest of the time (maybe a minute or two longer). My concern is that when i was done, i noticed the mid section of that outboard was hot. It was more than what i would consider warm, but not hot enough that i couldnt keep my hand there if i wanted. My questions are:
1. Should I have waited longer before restarting the motor after the alarm went off?
2. What should I be inspecting to see if I caused any damage due to overheating?
I suspect there wasnt enough clamping pressure on the flushing muffs, causing the boat to have an insufficent amount of water for cooling.
PostPosted: Thu Sep 08, 2022 11:33 am    Post subject: Reply with quote
Most likely no damage. The item initially would be the water pump impeller . It is rubber and if no water to lube it, then it may overheat and fail. But since the motor did well after the re-adjustment, and there was some "pee" stream, not likely there was damage.
The impeller should be changed if a decreased Pee and not due to obstruction, at about every 200 hours or every 3 years. I know of some which have lasted 8 years, and others which have failed in less than 50 hours,.
The engine itself should be fine.
ATPNW
Photos: Fellowship
PostPosted: Thu Sep 08, 2022 12:12 pm    Post subject: Reply with quote
Thank you for the quick reply. I am two years since the impellers were last changed.
On a somewhat related note, has anyone come across a good set of muffs for these smaller outboards? I see they make some with a clamp system that goes through the water intake.
PostPosted: Thu Sep 08, 2022 1:15 pm    Post subject: Reply with quote
One thing to consider when using muffs is the water pressure from the hose. Depending on the pressure you have, your impeller may get quite a boost and therefore may not need to work as hard (or at all) and the motor will still be cooled and you get a pee stream. Once you get out on the water, the impeller has to work unassisted and may not be up to the job.
ATPNW
Photos: Fellowship
PostPosted: Thu Sep 08, 2022 2:14 pm    Post subject: Reply with quote
Thanks, I had read this before too. I typically only turn my faucet about 1/4 fully open. It is had to gauge what amount of pressure that actually equates to. Any tips for finding the sweet spot?
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Thu Sep 08, 2022 2:28 pm    Post subject: Reply with quote
With the earmuff you also need volume, even more so if you don't have a very tight seal, and that often equal to high pressure. I sometime use a big trash can full of water, so I know all the pressure is from the engine water pump.
Stephan
PostPosted: Thu Sep 08, 2022 2:44 pm    Post subject: Reply with quote
I turn the water fully on. There is some pressure drop, since it is about 75 feet from the hose bib to the motor. Suggested water pressure at the muffs should be about 30 to 40 PSI. Mine is very close to that. There is always some leakage around the sides of the muffs.
Ssobol is right on with the see what the pressure is when you have the boat in the water--with the smaller engines you can usually fit a 5 gallon bucket around the lower unit, and have the hose running into the bucket, to double check the flow.
Also leave the motor at an idle--don't rev it up during "flush". When I have the boat in salt water, then I will use the flushing port (engine not running) and realize that the lower unit and impeller will not get full flushing.
PostPosted: Thu Sep 08, 2022 9:56 pm    Post subject: Reply with quote
If it's been two years since you last changed your impeller, it might be a good idea to change it again now with the overheat.
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Thu Sep 08, 2022 11:27 pm    Post subject: Reply with quote
I've had the hose valve half open before, and not enough water to get a good pee stream. I'd open it fully.
I had this same problem once. The 2006 Honda 9.9 just got back from the shop, in perfect condition, running like a top. The muffs somehow slid out of place a bit. When the alarm went off I had stepped away, but turned it off in about 10-20 seconds. Yes, the motor felt "hot", more than usual. Ever since that incident, it was really hard to start the motor. I tried flushing the carb bowl thru the drain screw with crab cleaner. This worked! The motor ran fine. And then it didn't.. .a few starts later, it didn't want to start again.. "My theory" is the the extra heat somehow loosened up some debris in the fuel system. These motors are notorious hyper-sensitive to anything in the fuel line... I think I have to rebuild the carb now...
Current boats:
1988 16' Angler - "E-fishn-C" (Project boat)
Also:
ATPNW
Photos: Fellowship
PostPosted: Fri Sep 09, 2022 11:19 am    Post subject: Reply with quote
Probably not a bad idea, I do have a couple replacement kits ready to go. Thanks for everyones comments here.
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Fri Sep 09, 2022 12:19 pm    Post subject: Re: Overheating Outboard on Flushing Muffs Reply with quote
Because there was some water flow out of the pee hole, it was probably good to re-start the motor immediately after adjusting the flushing muffs. You may want to inspect the exhaust manifold for cracks but I don't think you will find any.
One thing I noticed is that you took your boat home to flush the motor. I started out using flushing muffs but soon got tired of having to stay with the motor to ensure that the muffs did not slide or fall off. Now I park the boat over my lawn and use a 100 gallon Rubbermaid Stock Tank filled to the rim and flush both the main and kicker at the same time. https://www.rubbermaidcommercial.com/material-handling/farm-garden/stock-tanks/ The motor needs to be in the tank deep enough to cover the cavitation plate. I adjust the pee hole nozzles for overflow to go back into the tank. I attached a 3/4 in. ball valve with a hose thread to drain the tank afterwards while watering the lawn at the same time.
I realize that this method may not be practical or applicable for everyone but if you store your boat at home, this method may be a safe and reliable alternative.
Gary F
John&Robin
City/Region: Freeland
Vessel Name: C-Biscuit (was Wanda Fuca!)
Photos: C-Biscuit
PostPosted: Fri Sep 09, 2022 12:44 pm    Post subject: Reply with quote
When I use muffs I put duct tape over the water intake on the underside of the cavitation plate per the owner's manual. The one time I didn't I got an overheat alarm. Taped it and started back up with no alarm.
John and Robin
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Fri Sep 09, 2022 2:03 pm    Post subject: Re: Overheating Outboard on Flushing Muffs Reply with quote
Great idea - the 50s will fit in a 35 gallon round garbage can as well. I do that a couple times of year just to flush out the salt. At the end of the season, I add salt away for good measure. And if you don't feel like just idling them, because very little water flows through them at idle...just tossing that out there....you can let them rev to your heart's content and really get a good flush because now you basically have a run tank.
ATPNW
Photos: Fellowship
PostPosted: Sat Sep 10, 2022 11:34 am    Post subject: Re: Overheating Outboard on Flushing Muffs Reply with quote
I have considered this, but my question would be - How would you then use Salt Away? Or do you not use it?
Edit: I now see T.R. Bauer's suggestion with the Salt Away. I think ill try to incorporate this. Thanks!
ATPNW
Photos: Fellowship
PostPosted: Sat Sep 10, 2022 11:36 am    Post subject: Reply with quote
Thanks ill try this next time!
Page generation time: 0.0589s (PHP: 77% - SQL: 23%) - SQL queries: 28 - GZIP disabled - Debug on
