Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
Posted: Mon Sep 05, 2022 4:57 pm Post subject: Aluminum trailer weight vs galv for a Cdory 22..? |
Does anyone know the approximate weight difference? How much lighter would an alum trailer be for a 22? (single axle).. ? _________________ James Salay - Real Estate Broker / Investor, Engineer, Artist, Fisherman, Canyoneer, Outdoor Enthusiast
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
14.5' Drift Boat - "Wood Zeppelin" |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Mon Sep 05, 2022 5:13 pm Post subject: |
The manufacturer sticker on my Al tandem trailer says it weighs 600#. I have no idea how accurate that number is. |
Posted: Sat Sep 24, 2022 11:01 pm Post subject: |
I have a Pacific Tandem trailer with 2 long bunks and 2 short ones, and short side bunks. Kodiak SS brakes on all 4 wheels, and a single spare tire mounted to the winch post. The scaled weight on the empty trailer is right at 1100 pounds.
SleepyC
Posted: Sun Sep 25, 2022 4:13 am Post subject: |
Harvey, Is your trailer galvanized?
I would strongly advise a tandem axle trailer if you are doing any serious trailering. Single axle trailers are generally short haul and yard type of trailers for the 22. I had a single axle trailer, which came with one of my 22' and it failed after several years use. The cost differential is not all that much.
The weight difference is several hundred pounds, and depends on both the build quality of both the aluminum frame and galvanized steel frame. The axles, bunks, winch etc are all the same. _________________ Bob Austin
Posted: Sun Oct 02, 2022 8:02 pm Post subject: |
Yes, my trailer is galvanized. Sorry I missed that. And it is not the one in the pix, but theay are near twins, only difference is the tandem vs single axel.
Totally agree, for towing more than just short hops to the marina, you will appreciate the tandem.
SleepyC
The Current Pacific trailer
DayBreak
Joined: 16 Jul 2017 Posts: 1022 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Tue Oct 04, 2022 2:10 pm Post subject: Re: Aluminum trailer weight vs galv for a Cdory 22..? |
Wood Zeppelin wrote: | Does anyone know the approximate weight difference? How much lighter would an alum trailer be for a 22? (single axle).. ? |
Our trailer is double axle for a 23 Venture Sport, but when we bought new, the weight difference was nearly 100 lbs. between an aluminum vs. galvanized in comparison with both being double axle. Our tow vehicle at the time (Dodge Dakota) was marginal on GVWR and so we went with aluminum. You may wish to compare different trailer manufacturers to find the exact difference in weight. Also, even with a 22 Cruiser or 23 Venture, going with electric over hydraulic brakes is quite nice and makes for a safer tow rig. We are very satisfied in going with a E Z Loader Trailer. http://www.ezloader.com/ _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
