Square-drive stainless screws
JMacLeod
City/Region: Stuart
C-Dory Year: 2018
Vessel Name: C-Shalom
Photos: JMacLeod
PostPosted: Sat Aug 13, 2022 1:09 pm    Post subject: Square-drive stainless screws Reply with quote
I noticed the stainless screws used in the window frames are a different composition than the stainless used in the door frames and grab handles.
All were exposed to the same conditions in this spot, but only the window screws show pitting and green corrosion.
PostPosted: Sat Aug 13, 2022 2:25 pm    Post subject: Reply with quote
Seems like you have something other than SS screws in the window frames.
There are different grades of SS (e.g. 304 and 316). 316 is better than 304. Eventually 304 will show some surface rust. Never seen SS turn green.
PostPosted: Sat Aug 13, 2022 3:13 pm    Post subject: Reply with quote
It would be interesting to see if these are ferrous metal. Take a magnet and see if it sticks to the Robertson (name of square drive--comes In 3 different sizes) screw. If green, then suspect some copper plating perhaps under chrome?
Agree with ssobol ref types of SS. However even some SS labeled "316" from China, may not really be 316 alloy.,
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sat Aug 13, 2022 5:08 pm    Post subject: Reply with quote
https://www.trawlerforum.com/forums/s3/stainless-steel-brass-28408.html
This contains some good info.
Rob
JMacLeod
City/Region: Stuart
C-Dory Year: 2018
Photos: JMacLeod
PostPosted: Sun Aug 14, 2022 2:22 pm    Post subject: Reply with quote
Nope. Didn't stick.
Found a good variety of Robertson screws at Albany County Fasteners.
https://www.albanycountyfasteners.com/search.html?Per_Page=48&Search=square%20drive%20screw&Sort_By=bestsellers
I forgot the exact count, but 250 screws is enough to replace them all.
JMacLeod
City/Region: Stuart
C-Dory Year: 2018
Photos: JMacLeod
PostPosted: Sun Aug 14, 2022 2:24 pm    Post subject: Reply with quote
Rob
A lot to digest.
Thanks Rob.
Page generation time: 0.0291s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
