bshillam
Joined: 21 Aug 2007 Posts: 778 City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
Posted: Wed Jun 15, 2022 12:19 pm Post subject: SOLD- 2004 22' C-Dory, 2021 90 HP Honda |
I have a 04 22' C-Dory that I am transporting across the country. Can drop anywhere in the lower 48. New Honda motor with less than 10 hours! If you have been looking for a ready to cruise CD this would could be the one. Pictures in my album. Newer 2016 dual axle trailer too!
Full camper back
Fenders
Raised cockpit floor!
Some of the stats,
2004 C-Dory 22 Cruiser
HULL I.D. NUMBER: CDO22191A404
TOTAL POWER: 90 hp
CRUISING SPEED: 16 Mph
MAX SPEED: 28 Mph
FUEL CAPACITY: 46 Gallons
DC POWER: 2x, 12 Volt Batteries
TYPE: Gasoline Outboard
MANUFACTURER: 2021 Honda
MODEL NUMBER: BF90D
SERIAL NUMBER: 1413208
ENGINE HOURS: Reported to be 9 hours.
PROPELLER: Stainless Steel 3 Blade, 14” diameter.
BATTERIES: Two, group 24 starting batteries.
Both were properly secured in battery boxes,
And properly wired.
BATTERY CHARGER: Pro-mariner,110 Volt, 12 amp.
Mounted at the transom
And connected to both batteries. The charger
Must be connected to shore power with an
Extension cord. Was Operational.
GENERAL CONDITION: Both batteries were dated 2021 and were
Properly secured. All
Components of the charging system were
Well maintained and operational.
FUEL SYSTEM
NUMBER OF TANKS: Two
MATERIAL & CAPACITY: Plastic tanks, 23 gallons each.
Tanks are secured properly
And are clean and leak free
In areas that are visible.
TANK LOCATION: Tanks are located at the transom.
FILL PIPE LOCATIONS: Port & Starboard side decks
Marked “GAS”.
HOSE MATERIAL: Fill hoses are Type A2 and
Are clamped and secured
Correctly.
STEERING SYSTEM
TYPE: Manual
MANUFACTURER: Teleflex
NUMBER OF STATIONS: One
LINES & FITTINGS: Reinforced flexible lines with
Metallic fittings.
TRIM TABS: Lenco Trim Tabs.
ELECTRICAL SYSTEMS
VOLTAGE: Lead acid battery powered
12 volt system.
BATTERIES: Two, group 24.
Were properly wired & secured
MAIN BATTERY SWITCH: Rotary type, mounted in
A transom compartment.
PANEL: Main Electrical panel and load
Center is located in cabin.
BREAKERS & SWITCHES: Panel with switches and
Breakers is located at the
Helm station.
OUTLETS: One Cigarette lighter style
Outlet at the helm station.
CONNECTORS: Round lug captive type
GALLEY
STOVE: Wallas, 2 burner, alcohol stove.
Was not tested due to no fuel on-board.
SINK: Stainless steel sink, with manual foot operated
Pump. Was operational. No leaks sighted.
ELECTRONICS & NAVIGATION EQUIPMENT
STANDARD HORIZON Matrix GX2000 VHF radio
Was operational
RITCHIE 3” Compass
Was operational
GARMIN GPSMAP with Sidescan Sonar
Was operational
UNIDEN QT-206 Depth Gauge
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Wed Jun 15, 2022 12:55 pm Post subject: |
Upgrades/installs/recent maintenance
October 2018
West Marine dual battery charger
March 2020
West Marine auto 800 bilge installed
Sep 2020
New battery cut off installed
Trailer serviced
Upholstery repaired cover
October 2020
Fuel filter replaced
Replaced 50amp waterproof thermal circuit breaker
Added Stainless steal Solars propeller
June 2021
2 New West Marine batteries installed
July 2021
New foam for all cushions
New Honda BF90 installed with new shift lever and cables. *Hour meter read 948 when motor was replaced
New filler water hose and new hoses to sink installed
New foot pump for sink installed
New bilge discharge hose installed
All L-brackets in cabinetry replaced with new stainless steel and ss screws
Significant mentions
2016 Load Rite tandem trailer w/ spare tire
Swim platform, factory upgrade
Lenco trim tabs
Full enclosure bikini with plastic windows as well as screened windows
Full boat cover
Cabin door screen
Anchor and 150’ anchor rode |
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Wed Jun 15, 2022 12:58 pm Post subject: |
Sorry, tried to edit the original post. Boat is being sold for $40k. Transportation is negotiable.
Feel free to call, 503-781-9967 or email bshillam@hotmail.com |
Esmi2
Joined: 26 Aug 2016 Posts: 35 City/Region: San Luis Obispo, CA
Posted: Wed Jun 15, 2022 11:20 pm Post subject: |
Very very nice.
Note to lookers: This boat for sale is on Page 2 of his album in the last folder. (I made some incorrect assumptions the first time I looked for it!) _________________ Wannabe |
bshillam
C-Dory Year: 1981
Photos: My Heaven
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Sun Jul 03, 2022 10:28 am Post subject: Update |
Looking over the boat gelcoat is in need of repairs in several areas. So I am going to reduce the price to reflect the work I believe it should have.
$38k.
Bonus, has Wallas cooktop! Full camper back. Icebox was removed but not replaced. Build out drawers or fit in a better cooler/frigerator?
Boat is in Portland, OR. |
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Tue Jul 05, 2022 9:04 pm Post subject: |
More pictures added to the album just taken a few days ago. |
CB76
Posted: Sat Jul 09, 2022 11:27 am Post subject: |
Hi Bill,
Interested in the boat, sent you a PM.
Chris _________________ Looking for a C-Dory to call my own! |
bshillam
C-Dory Year: 1981
Photos: My Heaven
haakebecks
Vessel Name: Next Adventure
Photos: haakebecks (Name TBD)
Posted: Mon Jul 18, 2022 7:13 pm Post subject: |
Sent you a DM. |
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Wed Jul 20, 2022 11:04 pm Post subject: |
Offer received, pending. |
bshillam
C-Dory Year: 1981
Photos: My Heaven
Posted: Tue Aug 02, 2022 4:09 pm Post subject: |
Check deposited, boat is considered Sold.
Thanks for everyones interest! |
