fred09
Posted: Mon May 30, 2022 5:27 am Post subject: charter plotter suggestion |
Looking to upgrade my charter plotter in the future, looking for opinions on the best models/brands, etc, being drawn to the Garminge but would like to see what people have, I will be using a through hull transducer. |
Joined: 02 Nov 2003 Posts: 19934 City/Region: Pensacola
Posted: Mon May 30, 2022 9:40 am Post subject: |
All of the current MFD (Multi Function Displays) are good. I feel that the Garmin is the easiest to use.
With a shooting thru the hull transducer you are going loose several of the functions that modern fish finders use: Down Scan, Side Scan, and any of the 3 D renderings.
Also you will need to remove all of the core, and get to sold glass between the face of the transducer and the water. You can use the transom transducer to shot thru the solid glass. Even the sump areas (transom, and in some just inside or just outside the cabin door) are cored under the inner fiberglass.
You can then mount the transducer into epoxy, silicone, or mineral oil (make box) to have 100% contact with the glass on the inside of the hull.
You will also need to decide what level of charting you need. Basic, or very detailed charts. Also do you need lakes, and rivers, just coastal or both? Do you boat in the USA, Canada, Mexico, or all?
Do you want only touch, only buttons and dials or both? I find at times the touch are harder to use. Another issue is like I experienced yesterday. I hadn't turned on my Raymarine touch screen, and was depending on a separate depth sounder, as I broke in a new kicker motor. Then I wanted to use the touch screen. I had left the black cover in place, and there was no shade at the helm. Thus the touch pad was very hot, and would not respond to my finger touch...(Not usually going to be an issue on C Dory pilot house boat) _________________ Bob Austin
Peter & Judy
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
Posted: Mon May 30, 2022 10:29 am Post subject: |
My 2005 C-Dory still had the original Raymarine C-80 system until this month. I have just upgraded it to a new Raymarine Axiom+ system, which includes a Axiom 9" for the chart plotter and new Quantum 2 Doppler Radar. I add a second Axiom 7" which is dedicated to the sonar and fish finder. I bought the RV-100 sonar which as 3D and and side vision. I also updated the electronics for my autopilot. I only had the boat on the water for a few hours to make sure things were working and next week I will be going on my first cruise to see how the system works and learn how to use it.
P.S. I will soon have the old system for sale _________________ Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
HMCB (Her Majesties Cute Boat) |
Posted: Mon May 30, 2022 2:46 pm Post subject: |
Here's an idea. Borrowed from a friend. Keep the thru hull 'ducer and set it up to a depth gauge by itself on the dash. Then add a new (fancy) transom mounted transducer with a new Raymarine Plotter. Provides a bit of redundancy and less likely to loose depth function on the through hull. Axium is nice. Axium Pro gives you knobs and buttons that will work with wet hands or in the heat. I just replaced my old Raymarine C-120 with a new 12 Pro and love it. More intuitive than the old Rm stuff, quick and requires much less power draw.
SleepyC
Joined: 03 Mar 2005 Posts: 3560 City/Region: Valley Centre
Posted: Mon May 30, 2022 2:56 pm Post subject: |
With a shoot through transducer, it appears that you either have a sailboat or have come from a sailing background. As Dr. Bob/thataway pointed out, this prevents you from full use of existing depth sounders.
Mounting a depth sounder on the transom is the preferred way.
Boris |
mutski
Vessel Name: Just Us
Photos: Just Us
Posted: Tue May 31, 2022 1:16 am Post subject: |
I was overwhelmed with chartplotter choices, so I visited West Marine to see them in person at get advice. It's worthwhile if you are having trouble deciding.
I wanted to stay under $1000, and looked at simpler models geared to small boats - Garmin Echomap, Simrad Cruise. Ray Marine Element, Lorance Hook. I thought a 7"screen was adequate to display navigation charts and sonar and even a split screen; I thought a 9"screen might take a lot of room on the C-Dory dash.
I thought Garmin was the easiest to navigate, with Ray Marine close behind. I thought the Garmin touchscreen was easier than buttons for navigating display screens and features, and the Simrad buttons seemed especially bothersome. The salesman told me some people find touchscreens difficult on a bouncing boat, but the Garmin has several buttons that can be set to commonly used screens. The Ray Marine uses buttons, but they were more intuitive and easier to navigate that the Simrad buttons. The Lorance chart simulation didn't seem to be working, so I didn't spend much time looking at Lorance.
The salesman told me that Ray Marine was the only one of these inexpensive chartplotters that will display 3D sonar images of the bottom with the supplied transducer. Garmin will do it with an expensive add-on transducer. RayMarine included US and Canadian coastal charts;Garmin. Lorance and Simrad included only US charts. Ray Marine was also the only one of the less-expensive chartplotters that would accept radar input. The salesman told me the disadvantage of Ray Marine is that its chartplotters use older connecters; it you plan to add a lot of peripherals, you will need adapters.
I finally bought a Garmin Echomap 74sv UHD, primarly because I like the touchscreen and the navigation charts. The Garmin charts are excellent, but the manual says I can also download free NOAA charts, which I may do since I am used to the old paper variety. I am more interested in beachcombing and exploring than fishing, but the Garmin sonar is impressive. The Echomap gives a traditional broad-beam display, a high-definition narrow-beam display and side-view sonar. The high-definition display shows incredible detail. |
mutski
Photos: Just Us
Posted: Tue May 31, 2022 1:17 am Post subject: |
cbbernard
State or Province: RI
Vessel Name: SEA STORY
Posted: Tue May 31, 2022 6:29 am Post subject: |
I went through a similar process as mutski and ended up with a Garmin for similar reasons, though a different model. Keep expandibility in mind. If you are not buying radar now but might down the road, not all Garmin chartplotters are also MFDs and some will not let you add radar later without adding a second screen. |
Joined: 27 Oct 2012 Posts: 2945 City/Region: SW Michigan
Posted: Tue May 31, 2022 10:33 am Post subject: |
WM only sells certain brands of plotters.
I recently got a Lowrance HDS Carbon 9. It has a 9' screen which is higher resolution than most (1280x720), has a touchscreen and button control, comes with a sidescan/down image/CHIRP transducer, NMEA 2K and 0183, and C-MAP charts for US and Canada inland and coastal.
Less than $1K. |
mutski
Photos: Just Us
Posted: Tue May 31, 2022 11:36 am Post subject: |
I was trying to stay under $1000. The last time I put electronics in a boat was 25 years ago. I had a depth sounder that plotted a line for the bottom and occaisionally showed something like a fish in the water column. I used paper charts and eventually a hand-held GPS for navigation. ALL of the chartplotters available today are light years ahead of what I'm used to, lol.
Radar would be nice, but this is a 22-foot flat-bottom boat, not an off-shore cruiser. Another option is a VHF radio with AIS, which will plot large vessels with their courses on my $700 Garmin chartplotter. If you want to go that route, make sure you get a plotter with NMEA communication. |
zuunami
Joined: 10 Aug 2021 Posts: 206 City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
Posted: Fri Jul 29, 2022 7:02 pm Post subject: |
The Garmin Echomap UHD 94sv (ocean water maps) recently came on sale at West Marine online for $699 (down from 899) and we're intrigued. We have an 10+ year old Raymarine we were thinking of replacing.
But when I went to the actual Garmin site, it says the unit is discontinued, and the new similar unit "now ships with a newly redesigned transducer" at a price of $1299. I'm wondering if anyone knows whether there are problems with the GT54 transducer that is included in the price of the one I'm looking at with West Marine? (Not going to West Marine, the nearest is 3 hours away  _________________ Karen W. and Robert R.- Fort Bragg, CA - Oh Buoy! |
zuunami
Photos: zuunami
Posted: Fri Jul 29, 2022 7:20 pm Post subject: |
Also, I'm surprised that the display is only 480 x 800 pixels. Is that common in this price range? Sorry, relative newbies here  |
ATPNW
Vessel Name: Fellowship
Photos: Fellowship
Posted: Fri Jul 29, 2022 8:06 pm Post subject: |
zuunami wrote: | The Garmin Echomap UHD 94sv (ocean water maps) recently came on sale at West Marine online for $699 (down from 899) and we're intrigued. We have an 10+ year old Raymarine we were thinking of replacing.
But when I went to the actual Garmin site, it says the unit is discontinued, and the new similar unit "now ships with a newly redesigned transducer" at a price of $1299. I'm wondering if anyone knows whether there are problems with the GT54 transducer that is included in the price of the one I'm looking at with West Marine? (Not going to West Marine, the nearest is 3 hours away  |
I have the 94USV. There is nothing wrong with the GT54 that I am aware of. They have a newer model with better side scan now, the GT56. I think they are just clearing out the old inventory. I ended up selling the GT54 that came with mine and went with the GT51 (i think thats the model) as it was better suited for ocean trolling depths |
zuunami
Photos: zuunami
Posted: Fri Jul 29, 2022 8:28 pm Post subject: |
thanks, in what way was the 51 better suited for ocean trolling? |
srbaum
Joined: 30 Aug 2010 Posts: 788 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Fri Jul 29, 2022 8:58 pm Post subject: |
Zuunami,
My boat has the Garmin Echomap UHD 94sv, with the GT54 transducer and is has worked flawlessly. _________________ Steve Baum
Homeport of Portsmouth, VA
