Good shoot-through-hull transducer location?
mutski
City/Region: Homer
Vessel Name: Just Us
Photos: Just Us
PostPosted: Fri May 06, 2022 8:53 pm    Post subject: Good shoot-through-hull transducer location? Reply with quote
I am buying a 2005 22 Cruiser, and getting conflicting reports about whether there are uncored portions of the hull when I could install an in-hull transducer. Has anyone found a good location with no core?
I mistakenly put this question in the C-Dory Boats for Sale forum, thanks to Barry Rietz for pointing this out. Barry tells me he ground through to the outer hull under the galley counter, filled the hole with bubble-free fiberglass and installed an in-hull transducer there.
I am reluctant to grind into the hull. Has anyone found an uncored spot in the bottom where an in-hull transducer works without cutting through the core to the outer hull?
PostPosted: Sat May 07, 2022 10:19 am    Post subject: Re: Good shoot-through-hull transducer location? Reply with quote
You could check the sump at the very back of the cockpit where the drain hole is. I’m not sure that it is not cored, but this area is not as thick as the rest of the hull floor so it might be. FWIW, I have a transom mount transducer mounted with a stern saver block.
PostPosted: Sat May 07, 2022 10:36 am    Post subject: Re: Good shoot-through-hull transducer location? Reply with quote
Most boats have about half the coring in the sumps. (Some have a sump just inside of the cabin door also.
I have always used the transom mount transducers (especially now, with the side and down scan transducers)
Page generation time: 0.0274s (PHP: 59% - SQL: 41%) - SQL queries: 16 - GZIP disabled - Debug on
