C-Dory Hull Shape(s)? 22 Cruiser
Yosef
City/Region: Eastern Washington (state)
C-Dory Year: 1988
Vessel Name: Heron
PostPosted: Tue Apr 26, 2022 3:57 pm    Post subject: C-Dory Hull Shape(s)? 22 Cruiser Reply with quote
Crawled under an '88 22' Cruiser and the "V" is held all the way to the transom.
Somehow, I got the idea that C-Dory hulls were V's from the for end to maybe 2/3 the way back where it makes a flat area starting on the V and flattening & widening to maybe 2.5' wide at the transom.
Are all C-Dory hulls V's from stem to stern?
-Yosef
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Tue Apr 26, 2022 4:39 pm    Post subject: Reply with quote
I believe the original models were completely flat starting well forward of the transom. Newer C-Dory's have a very slight (couple of degrees) deadrise at the stern.
Are you sure you were looking at a C-Dory? How much of a "V" did you see? Pictures would help.
I'm sure others with more precise historical knowledge will chime in.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
PostPosted: Tue Apr 26, 2022 10:51 pm    Post subject: Reply with quote
To my knowledge all of the C Dory 22 were flat iron dory until 1987, Then the hulls are like they are today. There is a variable dead rise ending at the transom as noted above at about 2 to 4*.
The Cape Cruiser/Ventures have a bit more dead rise aft.
There were some of the 26/27 hulls which had a deep V all of the way aft--and it may be one of these early 26/27 boats you had seen.
PostPosted: Tue Apr 26, 2022 10:52 pm    Post subject: Reply with quote
Yosef
C-Dory Year: 1988
Vessel Name: Heron
PostPosted: Sat Apr 30, 2022 12:29 pm    Post subject: 1988 22' cruiser hull shape Reply with quote
If you visit https://www.youtube.com/watch?v=wCIjkHzEEgU and fast forward to 18:16 it shows the "flat area" at the transom.
The 1988 22' cruiser I'm looking at has a "v" hull shape at the transom. My understanding of such a hull shape (V all the way) is that it will (vs hull with flat area):
1. Roll more,
2. Lean over when it's beached,
3. Use more fuel when on plane.
Are there any pluses to the hull shape I'm seeing on this '88?
-Yosef
PostPosted: Sat Apr 30, 2022 12:36 pm    Post subject: Reply with quote
The U tube video you link to shows the almost flat transom dead rise--and is what the post 1987 boats all have.
The advantage of the deep 'v ((24 to our last 26* dead rise is that they cut into chop much better without pounding.
They are less stable at rest, use more fuel, roll a little more.
Page generation time: 0.0355s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
