ssilver
State or Province: NY
Vessel Name: Pearly Shell
Photos: Pearly Shell
Posted: Tue Apr 26, 2022 12:34 am Post subject: 22 Cruiser prop options |
Our 22 Cruiser is generally loaded on the moderate side. 2 adults midsize dog, weekend supplies. Boat has a newer 90 Suzuki alum Michigan wheel vortex 14" x 15 pitch. That prop works real well but now has a ding on one blade. I carry a spare Michigan wheel vortex 13" x 19 pitch. Just curious if anyone has any real world experience w/ that setup? The motor was originally mounted on a 17 whaler w/ a SS 14x20 that worked ok w/ a light load, we bought the 13" x 19 pitch for rough water and heavy loaded trips. Just curious what to expect using that on the C-Dory. We do have trim tabs and the permatrim. So essentially dropping an inch in cup and adding 4 in pitch. |
Joined: 02 Nov 2003 Posts: 21469 City/Region: Pensacola
Posted: Tue Apr 26, 2022 11:45 am Post subject: |
Quote: | I carry a spare Michigan wheel vortex 13" x 19 pitch. Just curious if anyone has any real world experience w/ that setup? The motor was originally mounted on a 17 whaler w/ a SS 14x20 that worked ok w/ a light load, we bought the 13" x 19 pitch for rough water and heavy loaded trips. Just curious what to expect using that on the C-Dory. We do have trim tabs and the permatrim. So essentially dropping an inch in cup and adding 4 in pitch. |
The 13 1/2" diameter x 15" pitch is "normal" most C Dory 22 with a 90 hp outboard. But Suzuki with different lower unit gearing can use large props and high pitched props.
What was the WOT RPM and WOT speed with the 14X15? you have dropped an inch in diameter, not "cup". Cupping is not measured in inches...
Generally aluminum props are relatively in-expensive, and it would be best to stay with a known diameter and pitch which achieves your proper WOT and highest speed. My gut tells me that the 13 x 19 will still be a bit aggressive, and slightly over propped.
The rule of thumb is: For every inch of change in prop diameter the RPM varies by about 500 RPMs and every inch of pitch changes the RPM by approximately 150 to 200 RPM. The smaller diameter will be less efficient. It may be fine until you "get home". You cannot compare a 17' Whaler with a 22 C Dory.
It stil boils down to WOT RPM and Speed to give some indication of how it is performing on a specific boat. _________________ Bob Austin
ssilver
Posted: Tue Apr 26, 2022 7:49 pm Post subject: |
I was seeing max RPM 6300 w/ the 14” x 15 @ 30-33 mph depending on load and current.
I just happen to have the 13” x 19 and was curious if anyone else had used it. I want to get out and do some fishing the striped bass are running and plan on dropping it in marina in about a week or so. Early in the season the river is full of debris so if I was to ding up another prop I just assume it be one I already have. I do not have any long range trips planned just a few miles north and south on the river.
Max RPM range is 5300-6300 sounds like the 13x19 should be between 6000-6200. I get I am not comparing apples to apples w/ a 1000lb skiff vs the C-Dory just sharing why I have a bunch of extra props. I also played w/ outboard height with the Whaler as it was pretty convenient sitting on a trailer in the driveway when not in use.
Spot on the aluminum ones are cheap I paid around $125 for them compared to around $500 for the stainless one I have. If it turns out the 14”x15 is that much better I will certainly order a new one before any long range trips.
Thanks for your input Bob much appreciated. |
Posted: Tue Apr 26, 2022 10:39 pm Post subject: |
If you can turn up the 6,000 with either prop, you are on the money. It may be that one is a bit more efficient. The Speed is about what you would also expect with the correct prop. |
Foggy
Joined: 01 Aug 2013 Posts: 1580 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Thu Apr 28, 2022 9:40 am Post subject: |
With your 'moderate loading', you would be better off with twin 50s vs single 90 hp.
Consider the prop area difference; 2 50s, with a 11.6" dia prop, has 845.5 sq in
of prop pushing the boat.
A single 90, with a 13.5" dia prop, has 572.5 sq in of prop push; a difference of
just under 50% more 'push' area (surface area of propellers) with the twins.
This may not help your current situation already having a single engine, but maybe
for others who are trying to solve the old dilemma: one engine or two.
Aye.
Grandma used to say, "Pie are round."
Grandpa used to say, "No, pi r square." _________________ Keep an open mind just enough to not let your brain fall out. |
Joined: 27 Oct 2012 Posts: 3580 City/Region: SW Michigan
Posted: Thu Apr 28, 2022 10:42 am Post subject: |
Foggy wrote: | With your 'moderate loading', you would be better off with twin 50s vs single 90 hp.
Aye.
Grandpa used to say, "No, pi r square." |
I don't think that "push area" makes much difference. It is more about pounds of thrust. A large "push area" at low thrust is going to give similar results as a small area at high thrust if the total thrust is the same.The difference is that a large "push area" has more drag potential. There is some efficiency gained by having a larger slower turning prop vs. a smaller, faster one, but probably not enough to say that two props are more efficient than one in this situation. There is also this issue of the friction losses of two engines vs. a single one.
That said, there are advantages to two motors vs. a single that don't have to do with total efficiency. |
san juanderer
C-Dory Year: 1990
Posted: Thu Apr 28, 2022 12:57 pm Post subject: |
OH OH, This topic line is going to go no where.
Except, downhill into the swirling water thing. |
ssilver
Posted: Thu Apr 28, 2022 9:38 pm Post subject: |
HAHA san juanderer I will see the results soon enough I was thinking somebody might have a DF90 w/ the a 13” prop to cure my curiosity pre launch. I was more than satisfied w/ the results of the 14”x 15 and will not hesitate to get a new one.
As far as two outboards, if I was starting from a clean slate I would have defiantly opted for two forty or fifty horse outboards. Mostly for redundancy when going off shore.
I purchased the 90 for my Boston whaler that I had owned for over 20 years with the intention of keeping them together. Than we decided we wanted to something we could overnight on and started looking at boston whaler, parkers, Steiger crafts basically pilot house looking boats. Just browsing boat ads one day I found a 22 cruiser that had no outboard and really liked the look of the boat. After a little research I discovered a 90 would be perfect. I was thinking I could just put the new Suzuki on there and it would be perfect. I reached out to the guy and almost feel over hearing it sold a few days after it was listed. I started looking for another and kept reading about them and ran across this site and lurked for a while. The more I read about C-Dory I just had to have one. I found the one we ended up w/ and bought it. She had a perfectly functioning 2004 Honda 90 w/ around 800 hours. I bought the boat w/ the intention of putting the 2004 on my old whaler and 2020 Suzuki on the C-Dory. This summer we do not have any offshore trips planned but maybe next year I will pick up a kicker for piece of mind. I cannot justify getting twins at this point. I am thinking about our next boat. Who knows I am open looking at 36’ trawlers or maybe a Ranger or who knows maybe just keep the C-Dory. I am getting closer to a retirement from my current civil service position and leaning towards becoming some sort of snowbird. We will figure it out. |
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Fri Apr 29, 2022 12:39 pm Post subject: |
Agreed: Prop thrust a more appropriate term what I used above (prop 'push area'
most likely due to a momentary cerebral flatus while typing... thinking of prop
surface area). It's no excuse. My bad.
It remains my understanding that bigger prop surface area, and thrust, is helpful
with heavier loads - coming out of the hole and onto plane as well as at moderate
cruise speed pushing the heavier load.
So, if I were to get a CD 22 I knew was going to be loaded to the gunnels as the
norm, I would look into the engine(s)/propeller(s) combo giving the most thrust
for my set up.
Aye. |
Hunkydory
Joined: 28 Mar 2005 Posts: 2722 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Fri Apr 29, 2022 1:45 pm Post subject: |
Foggy wrote: | Agreed: Prop thrust a more appropriate term what I used above (prop 'push area'
for my set up.
Aye. |
Now well described & why on our often heavily loaded or run at very high altitude CD22 with the old twin Honda 40’s, I ended up after much experimentation with 10 pitch x 12 inch props. With the now Honda 60’s, I still carry one of those 10x12 props, so I can plane on one motor if needed.
SeaSpray
Joined: 12 Mar 2004 Posts: 1009 City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
Posted: Sat Apr 30, 2022 12:48 am Post subject: |
I have a Turning Point 21431930 - 4 blade 13.9 x 19 that I tried on my CD22 Suzuki 90. I liked this prop at first but when I loaded up and went on a trip I found it was too much. I switched to a 3 blade 13.9 x 17 that works better for my boat.
Don't know what shipping would cost, but it's like new and I don't expect to use it. Let me know if interested.
Steve |
ssilver
Posted: Sun May 01, 2022 9:14 pm Post subject: |
Thanks Steve, I bet the 4 blade would be a bit much for my setup as well. Thanks Sean |
san juanderer
C-Dory Year: 1990
Posted: Mon May 02, 2022 1:27 am Post subject: |
SeaSpray,
How many rpm could you get out of the 19 pitch loaded ?
And the 17 pitch ?
Was this the model with the two different blade configurations?
thanks |
SeaSpray
Photos: SeaSpray
Posted: Mon May 02, 2022 1:34 am Post subject: |
Sorry I don't remember the RPM numbers with he props. It has been over a year ago that I last ran that prop. The 19 prop is the one that needs the hub insert to fit the different motors.
Steve |
