Clayhotch@gmail.com
Posted: Mon Apr 11, 2022 12:37 pm Post subject: 125 hp on a 22 angler?? |
So I'm looking to replace the 90 hp my 22 angler. I want to get something a little bigger. Anyone know how a 125hp on this boat works?[/list] |
Hunkydory
Joined: 28 Mar 2005 Posts: 2662 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Joined: 02 Nov 2003 Posts: 20841 City/Region: Pensacola
Posted: Mon Apr 11, 2022 7:31 pm Post subject: |
Who makes a 125 hp outboard motor? How much does it weight? Has the boat every been in a freeze thaw cycle environment?
Usually the 115 hp is plenty of motor. Once you get over 30 mph the boats begin to be a little squirrelly. The larger motors are usually used when the boats are heavily loaded--such as Jay's will be for a long Alaska trip.
I would be concerned about the transom in a 1988 boat. I have seen a broken transom with a larger motor, even in a newer boat. The boats at the time were rated for a 70 to 75 hp 2 stroke. Although there has been no substantial design change, be sure that there is no moisture in the transom. I would use a moisture meter, sound out the transom, especially when the 90 hp is off the boat--and you can check the mounting holes for potential water intrusion. _________________ Bob Austin
Mike B
Joined: 23 Apr 2011 Posts: 39 City/Region: Staten Island
State or Province: NY
Vessel Name: Remembrance
Photos: Remembrance
Posted: Fri Apr 15, 2022 5:30 pm Post subject: Re: 125 hp on a 22 angler?? |
[quote="Clayhotch@gmail.com"]So I'm looking to replace the 90 hp my 22 angler. I want to get something a little bigger. Anyone know how a 125hp on this boat works?[/list][/quote]
The manufacturers plate on my 22' Angler says 115hp is the limit. I have a 115 yamaha and its scary fast. I wouldn't go over 115. Pay attention to the weight of a new engine. |
