Honda 150 Oil in Air Box
Fishstix2
City/Region: Cape Coral
Vessel Name: PiraC
Photos: PiraC
PostPosted: Fri Mar 11, 2022 2:12 pm    Post subject: Honda 150 Oil in Air Box Reply with quote
Hello all, have had something that has just come up on our Tomcat Honda 150 port motor. Found that there is oil in the air box, so there is a drain tube at the bottom of the air box and I have some oil coming out of tube. A little more when tilted up. My mechanic believes this is from blow by from cylinders but he’s not sure. Has anyone experienced this issue with Honda motors or have a theory?
Best
Rick and Anita
PiraC
TomCat 255
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Mar 11, 2022 2:31 pm    Post subject: Re: Honda 150 Oil in Air Box Reply with quote
Best
If you didn't poor it in the air box it must be blow by. Wrong prop (lugging) or mostly low speed operation can/will cause this.
Go get some Yamaha Ring Free and follow directions. THEN Change your oil & keep an eye on it.
Good luck & let us know. Thumbs Up
Fishstix2
Vessel Name: PiraC
Photos: PiraC
PostPosted: Sat Mar 12, 2022 9:18 am    Post subject: Reply with quote
Tsturm, thank you for your response, it’s interesting you mention the wrong prop can cause. So, when I bought the boat the previous owner had changed the 3 blade Honda props with 4 blades. I liked the 4 due to lift out of hole and on plane at lower rpm’s. But, I had heard that 150’s struggle with the heavier 4 blades? Wondering if I should put the 3 blades back on and check results?
tsturm
Photos: JMR-TOO
PostPosted: Sat Mar 12, 2022 9:51 am    Post subject: Reply with quote
As long as the prop chosen will make the suggested wide open throttle rpm (whatever the manual says 6000 rpm?) it's the correct one.
My Suzi is 6200rpm.
Barry Rietz
City/Region: Sierra Vista
PostPosted: Sat Mar 12, 2022 3:26 pm    Post subject: Honda BF150 Oil In Airbox Reply with quote
Helpful information you should know:
http://www.marineengine.com/boat-forum/showthread.php?394001-Honda-BF150-Leaking-oil
Barry Rietz
N9DXC
BTDT
City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
PostPosted: Sat Mar 12, 2022 4:56 pm    Post subject: Reply with quote
How many hours on the 150?
John & Vicki Clark
C-Lark Wine Down
Tomcat 255
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sat Mar 12, 2022 8:53 pm    Post subject: Reply with quote
I'm reluctant on the blow by theory - unless your boat is blowing out clouds of light blue smoke most of the time. What does your PCV chamber look like? If it's full of oil as well, then ok I'm buying it. If it's not, then you can rule blow by out and start searching somewhere else.
Fishstix2
Vessel Name: PiraC
Photos: PiraC
PostPosted: Sun Mar 13, 2022 11:52 am    Post subject: Reply with quote
They have 1100 on both motors
Page generation time: 0.0252s (PHP: 75% - SQL: 25%) - SQL queries: 25 - GZIP disabled - Debug on
