Matching the gray of molded in non-skid on 87 Classic
colvosview
City/Region: Gig Harbor
Vessel Name: C-heeto
PostPosted: Sat Mar 05, 2022 12:32 pm    Post subject: Matching the gray of molded in non-skid on 87 Classic Reply with quote
I'm filling a couple of holes in the molded non-skid area on the bow. Has anyone used a paint or blend of colors that is similar? I'm planning to just do a touch up, and not paint all the gray. But my boat will never be absolutely pristine, so in this instance, close is ok.
David S
Gig Harbor, WA
Barry Rietz
City/Region: Sierra Vista
PostPosted: Sat Mar 05, 2022 2:25 pm    Post subject: Filling holes in non-skid Reply with quote
David, My 2004 C-dory is presenting with the same issues. The holes should be cleaned with acetone and filled with epoxy resin first. Once cured, I plan to use gelcoat mixed with a small amount of talcum to prevent running and the possibility of future cracking. The applications would require using small 'dabs" carefully placed on top of the cured epoxy. I'll be watching to see if another C-brat has done this type of repair and how it has lasted.
Barry Rietz
N9DXC
Page generation time: 0.0247s (PHP: 57% - SQL: 43%) - SQL queries: 15 - GZIP disabled - Debug on
