25' C Dory, Length of boat on trailer
scooper
City/Region: Newton
PostPosted: Mon Jan 03, 2022 11:29 am    Post subject: 25' C Dory, Length of boat on trailer Reply with quote
I'm trying to decide if I can fit a 25' C Dory in my driveway, which is a little over 30' in length. Does anyone happen to know the length overall of the 25' boat on an average trailer? Thanks!
SCooper
PostPosted: Mon Jan 03, 2022 11:42 am    Post subject: Reply with quote
On the trailer, Journey On is 32 feet, from the hitch to the back of the motor.
PostPosted: Mon Jan 03, 2022 3:10 pm    Post subject: Reply with quote
The answer I guess is "it depends". My 22 on the trailer needs 28'.
PostPosted: Mon Jan 03, 2022 4:42 pm    Post subject: Reply with quote
My 25 on a trailer is about an inch too long for a 30' rental unit. If you're driveway is a little bit over 30', I think it'll fit. Colby
scooper
City/Region: Newton
PostPosted: Mon Jan 03, 2022 6:56 pm    Post subject: Thanks!! Reply with quote
Thanks for all the replys!! This forum is great! I remeasured the driveway again and it's actually longer than I thought. Even the 32' length will fit no problem. That means I can shop for a 25'!
PostPosted: Tue Jan 04, 2022 10:23 am    Post subject: Reply with quote
When you go shopping, measure the trailer's tongue length. I believe that's the length from the crossbar to the ball hitch. It'll directly affect the length and more importantly the ease with which you can tow the ensamble
When Journey On's trailer came from the factory it came with a 9' length tongue. That was hard to get around corners, back into our parking slot or take through a parking lot. The factory finally replaced it with an 8' but a 7' would be even better.
PostPosted: Tue Jan 04, 2022 11:49 am    Post subject: Reply with quote
On the other hand, a longer trailer tongue can make launching easier, especially on less steep ramps. Got to decide where your priorities lie.
PostPosted: Tue Jan 04, 2022 12:26 pm    Post subject: Reply with quote
Yes, of course, a longer tongue is good for launching. I've launched with the "short" tongue at dirt ramps in Spanish, Ontario, sandy ramps in Long Beach and steep ramps at Bellingham, as well as Lake Powell. Lake Powell was the only ramp that I wished for a longer tongue, about 5' longer. At the rest, I was able to keep the rear truck tires out of the water and still launch/retrieve. This may be an advantage of a roller trailer.
The "long" 9' tongue, however, gave me interesting moments going through the parking lot at Walmart. I must of cut over at least 10 concrete barriers getting out of there.
When launching, the additional tongue length is linear: 1 ft of additional tongue=1' additional water clearance. However, in trailering 1" of tongue length=several feet of turning radius. The change from 9'to 8'was magnificent for towing and I've never regretted the loss in launching.
scooper
City/Region: Newton
PostPosted: Wed Jan 05, 2022 1:27 pm    Post subject: Great Info! Reply with quote
Great info, thanks! I've been thinking a lot about issues like this so direct info about personal experience really helps.
PostPosted: Wed Jan 05, 2022 8:15 pm    Post subject: Reply with quote
A longer tongue will also tow easier, less sway, especially if it is a single axle trailer. And it will back with a slower turn response so maybe easier to keep in a straight line.
PostPosted: Wed Jan 05, 2022 11:36 pm    Post subject: Reply with quote
hardee wrote:
A longer tongue will also tow easier, less sway, especially if it is a single axle trailer. ...
You can get bouncing due to flexing of the longer tongue though. Need to be sure that your trailer has the capacity for your boat.
Page generation time: 0.0538s (PHP: 44% - SQL: 56%) - SQL queries: 28 - GZIP disabled - Debug on
