And so it begins Bottom Painting
Goto page Previous  1, 2, 3
PostPosted: Sat Feb 05, 2022 8:11 pm    Post subject: Reply with quote
Are those load range c or d? Mr. Green I'd be a little nervous just using 1/2". But has to roll better than on flat tires! Colby
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Sat Feb 05, 2022 8:19 pm    Post subject: Reply with quote
Well it’s nine ply Baltic Birch should last the 30’ I have to move it. I bet I can push it by hand now. I thought about carving 2022 AD in them didn’t think about giving them a load range.
Jody Kidd
KE7WNG
Northern, Utah
PostPosted: Sun Feb 06, 2022 3:48 pm    Post subject: Reply with quote
Load Range B for Birch. Laughing
jkidd
PostPosted: Sun Feb 06, 2022 8:16 pm    Post subject: Reply with quote
Got the load range B's mounted and does it ever sit low. Rolls nice and easy too.
Trailer back under the boat with 4 inches of clearance above the bunks.
PostPosted: Sun Feb 06, 2022 9:05 pm    Post subject: Reply with quote
Nicely done. I'm still impressed that only two 1/2" "wheels" didn't splinter under the strain. It'll be interesting to see how your paint holds up where the bunk boards go. Mine is already starting to wear off from loading the boat after many launches. More so where the bow runs up on the target boards. Colby
jkidd
PostPosted: Sun Feb 06, 2022 9:52 pm    Post subject: Reply with quote
Maybe 500 lbs per wheel they didn’t even have a problem when I slid then sideways to center the trailer. What paint are you using.
PS maybe I could carry some of them for spares.
PostPosted: Sun Feb 06, 2022 10:19 pm    Post subject: Reply with quote
I used the Pettit Hydrocoat Ablative bottom paint. Cleaned the bottom off of much of the old stuff that wasn't put on very well before I bought the boat, and then painted over that. I think when I redo it, I may take it down to the fiberglass and start from there with an epoxy coat. I can't tell if there was any primer coat originally or not. Didn't seem like it when I worked on cleaning the other stuff off. Next time I may just take it to a boat yard. Otherwise I may use the sandblaster rather than the pressure washer. Then again, most my boating is fresh water, so other than for cosmetics while on the trailer, I probably don't really need to worry too much about it.
jkidd
PostPosted: Sun Feb 06, 2022 10:27 pm    Post subject: Reply with quote
Was it the Pettit Hydrocoat Eco the waterbase paint?
PostPosted: Sun Feb 06, 2022 10:35 pm    Post subject: Reply with quote
Water based. But just the regular stuff, not the eco.
PostPosted: Mon Feb 07, 2022 10:45 am    Post subject: Reply with quote
Colby, please do not go below the gel coat. The reason is if you get into the glass, then individual fibers are exposed. Then if some abrasions occurs, there will be wicking of moisture. This is the same reason I tell people not to sand blast the bottom. Using dry ice or some less aggressive media can be done, just to remove the bottom paint, and not the gel coat.
PostPosted: Mon Feb 07, 2022 12:31 pm    Post subject: Reply with quote
Thanks Bob. I said fiberglass, but meant gelcoat. If I do it myself, probably just stick with the pressure washer and then sanding again... Colby
Page 3 of 3
Page generation time: 0.1619s (PHP: 84% - SQL: 16%) - SQL queries: 29 - GZIP disabled - Debug on
