zuunami
Joined: 10 Aug 2021 Posts: 227 City/Region: Fort Bragg
Vessel Name: Oh Buoy!
Photos: zuunami
Posted: Wed Dec 08, 2021 9:52 pm Post subject: Filling holes in the deck in the bilge area |
A previous owner screwed down wood containments for the battery and gas tank in the deck in the bilge area on our 16'er, about 10 in all. Just regular phillips screws We've taken them all out (some not without some effort since they were rusted), and we got some wood dust on a few, but it was dry. And the deck seems very solid, didn't find any soft spots at all. None of the holes are bigger than 1/4", and no deeper than 3/4". What's the current thinking on filling those, would Marine Tex be okay, or would another product be better to be sure it flows down and fully fills the hole? Thanks! _________________ Karen W. and Robert R.- Fort Bragg, CA - Oh Buoy! |
Joined: 27 Oct 2012 Posts: 3592 City/Region: SW Michigan
Posted: Wed Dec 08, 2021 11:49 pm Post subject: |
I had some epoxy specifically for flowing into things like that to seal them up. Don't remember what it was called. I would use something like that to seal the core and then fill it with thickened epoxy (e.g. West 610). |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Thu Dec 09, 2021 10:06 am Post subject: |
I have had good result with G-flex in filling holes - flows right in very nicely. There are a litany of other epoxies that will work too I'm sure. I've used marine tex before, and it has it's place, but I don't think you'll be able to get into those small diameter holes very well. |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Thu Dec 09, 2021 11:27 am Post subject: |
ssobol wrote: | I had some epoxy specifically for flowing into things like that to seal them up. Don't remember what it was called. I would use something like that to seal the core and then fill it with thickened epoxy (e.g. West 610). |
Probably Smith's CPES. Still considered the best by wooden boat builders, but pricey. The two pint kit is a lifetime supply for most people. No amine blush (which you wouldn't be able to remove in a screw hole before adding thickened epoxy). I would clean things out and make sure there is no moisture damage, then fill with a loose (honey consistency) thickened epoxy. West System used to have little ketchup packets of its epoxy so that you didn't need to buy a couple of cans. You can thicken with sawdust or flour if you don't want to spring for cabosil.
https://www.amazon.com/Smiths-Original-Clear-Penetrating-Sealer/dp/B019IKGDZI[/i] |
Joined: 02 Nov 2003 Posts: 21505 City/Region: Pensacola
Posted: Thu Dec 09, 2021 3:27 pm Post subject: |
We usually drill out these holes to be clean of rust etc--1/4" will work fine if you are not going to put more screws in--if more screws, then 5/16 and under cut the deck before putting epoxy plug in place.
Then work plain neat epoxy into each hole, using. a swab to work it into the sides of the core. Thicken the epoxy and then work that down unto filling the hole. I used the same mix of epoxy I had mixed for lining the holes with neat epoxy., I agree that Marine Tex is too thick to work down fully. _________________ Bob Austin
Roamad
Joined: 20 Jul 2021 Posts: 105 City/Region: Sacramento
C-Dory Year: 1988
C-Dory Model: 22 Classic
Vessel Name: Fika
Photos: Roamad
Posted: Thu Dec 09, 2021 6:04 pm Post subject: |
My 1988 16’er had the same blocks of wood screwed to the floor. Maybe they are a factory install? I’m hoping to reuse some to mount a new fuel tank. _________________ Now: 1983 22’ C-Dory Classic, 2001 Honda 90hp
Then: 1988 16’ C-Dory Angler, 2008 Mercury 60hp |
zuunami
Photos: zuunami
Posted: Thu Dec 09, 2021 8:05 pm Post subject: |
Roamad, I don't think wood put down with machine screws was a factory install I'm curious why you would want to put wood down in the bilge area? |
zuunami
Photos: zuunami
Posted: Thu Dec 09, 2021 9:17 pm Post subject: |
thanks everyone, got some epoxy flowed into those holes today. Now researching how to make a light weight fuel tank container that can slide in and out, and also how to move the battery to one of the seatboxs. So thankful for all of the resources here on C-Brats! |
Posted: Thu Dec 09, 2021 10:59 pm Post subject: |
I am not sure what you want in a fuel tank. I probably would buy a pre made plastic tank, and perhaps glue some slides of King Starboard (or any high density polyethylene strips to the inner side of the hull, to slide the tank on. 1/4" thick and roughen up the back, and cut some dove tail notches to give tooth for adhesive (either 5200 or G Flex epoxy) after flame treating the HDPE. |
zuunami
Photos: zuunami
Posted: Fri Dec 10, 2021 9:05 pm Post subject: |
thataway, we're thinking of two 3-gal tanks, one on each side, then moving the battery to the port seatbox (we're not going on long hauls, and like the idea of just moving and changing them out to keep fuel fresh), and yes, we would want to lay down some sort of lifters slanted toward the center so water can flow underneath, then figure out a tie down system. |
Posted: Fri Dec 10, 2021 10:43 pm Post subject: |
I was thinking of larger tanks--but the 3 gallon are easily handled. I use a 6 gallon as back up for my Honda EU2200 generator. Even the 6 gallon is easily handled. I wonder if a 3 gallon or 6 gallons total, would be enough the the cruising you want to do?
There are a number of ways of holding the tanks in place--but with smaller thanks you don't really need much. Gluing down strips of PVC lumber to the floor with epoxy and then screwing strap holders to them would work well. |
zuunami
Photos: zuunami
Posted: Sat Dec 11, 2021 9:11 pm Post subject: |
thanks, Thataway, we have two six gallong tanks, just trying to lighten the load. We won't be going more than 5 or 6 miles a day out of harbor per day. Finding a 3 gal tank with a decent review online is a different matter apparently with the new gas tanks. There's always the 6 gal tanks  |
Safetythird
Posted: Wed Dec 15, 2021 11:16 am Post subject: |
zuunami wrote: | thanks everyone, got some epoxy flowed into those holes today. Now researching how to make a light weight fuel tank container that can slide in and out, and also how to move the battery to one of the seatboxs. So thankful for all of the resources here on C-Brats! |
I'm doing almost the same thing on my 16'.
I want the battery under the passenger seat box, and more range though, so, larger tanks.
And somewhere to put fish. |
