Trim is very faded
kcohen4
City/Region: WILLIAMSBURG
Vessel Name: Annie M.
Photos: Annie M
PostPosted: Wed Nov 24, 2021 8:22 am    Post subject: Trim is very faded Reply with quote
My 2004 16 cruiser I guess has seen too much sun over its lifetime. I think it is beyond compound and waxing. I was thinking of having it painted. Their is a shop here with a larger spray booth for boat painting. Any thoughts on this? What questions should I ask the shop?
2004 16 Cruiser with 2019 50 Yamaha
1984 Grand Banks 36
1984 Boston Whaler 13
1982 CC Landfall 38
1979 Catalina 27
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Wed Nov 24, 2021 9:13 am    Post subject: Reply with quote
I would do a wetsand and compound and buff before painting it. My boat was really bad also but looks good as new now. It is a lot of work. I spent a couple days on it. If you are not physically up for it or don't have the tools I would imagine that a good boat detail shop would handle it and still be a lot less money than painting.
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Wed Nov 24, 2021 11:40 am    Post subject: Reply with quote
https://youtu.be/BgESHA-J01E
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
PostPosted: Wed Nov 24, 2021 5:41 pm    Post subject: Reply with quote
The trim will have to be sanded before painting anyway--so do a small amount with wet sanding. Get 1000 grit wet and dry, then using 1/4 sheet folded over a sanding block, keep dipping the sand paper (block) in a bucket of clean water, and see how it does. If working then go to 1500 grit and 2000 grit, then go to cutting compounds, and polishing compound. You should be able to restore it if not wet sanded before.
If you are going to have it painted, go with Awlgrip--Imron can also be used. Do not use car paint! The two part LP paints are not cheap to spray--and the technician has to be a perfectionist. You want to have any blemishes on the hull filled, sanded and faired before you try paint.
The wet sanding would be cheaper--once it has been sanded, keep it waxed. Not hard to keep up--but if it runs down, then it will will be harder to get another good job out of the gel coat.
Page generation time: 0.0451s (PHP: 63% - SQL: 37%) - SQL queries: 17 - GZIP disabled - Debug on
