Smitty.io
Joined: 05 Sep 2021 Posts: 15 City/Region: Santa Cruz
C-Dory Year: 1982
C-Dory Model: 22 Classic
Photos: Smitty.io
Posted: Tue Nov 02, 2021 12:42 am Post subject: |
As a start, I would plug in to shore power, get out your trusty Volt meter and read the voltage at your battery terminals on all settings of your battery switch. Then you can go down the rabbit hole noted.
If the voltage is above 12.6, they are getting a charge unless you have a 24V system.
Smitty |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Tue Nov 02, 2021 9:36 am Post subject: |
Smitty.io wrote: | As a start, I would plug in to shore power, get out your trusty Volt meter and read the voltage at your battery terminals on all settings of your battery switch. Then you can go down the rabbit hole noted.
Smitty |
Exactly You won't know much of anything until you start where you noted. |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Tue Nov 02, 2021 2:42 pm Post subject: |
Quote: | “due to the P12 Battery Charger’s ability to optimize charging for each battery bank” |
Dollars to donuts the marketing department wrote that..... _________________ Sandy McKean
Purchased Tosca in 2014
Re-powered to Yammi 200 in 2015 |
