canvas snaps
Steveeverton
City/Region: Twin falls
State or Province: ID
Vessel Name: ValHalla
Photos: Steveeverton
PostPosted: Mon Oct 25, 2021 10:29 pm    Post subject: canvas snaps Reply with quote
I recently had a cockpit cover made and installed with stainless snaps. After just a few months the snaps corroded and became difficult to snap or unsnap. Any suggestions for replacement snaps that might hold up better?
Thanks for the help.
kcohen4
City/Region: WILLIAMSBURG
Vessel Name: Annie M.
Photos: Annie M
PostPosted: Tue Oct 26, 2021 8:04 am    Post subject: Reply with quote
have you tried spraying a little WD40 on the snaps on the canvas. I had same problem and this made them like new.
2004 16 Cruiser with 2019 50 Yamaha
1984 Grand Banks 36
1984 Boston Whaler 13
1982 CC Landfall 38
1979 Catalina 27
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Tue Oct 26, 2021 8:33 am    Post subject: Reply with quote
There are several brands of snap lubricate that are sold for this. The one I use is called Snap Stick by Shurhold. I get it from Amazon. I also buy replacement snaps from Amazon or Mcmaster Carr. I just look for marine grade snaps.
Jody Kidd
KE7WNG
Northern, Utah
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Oct 26, 2021 11:14 am    Post subject: Reply with quote
There is also this pricey little gadget that allows you to separate the snaps without yanking on the material. You can use it like a lever against a hard surface or twist in when the snap is between two canvas pieces. I've had success with it. For replacements, look for stainless steel male and female (including the wire ring on female). Nickel-plated brass never holds up for me.
https://www.amazon.com/gp/product/B00GHU5PXO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
PostPosted: Tue Oct 26, 2021 5:45 pm    Post subject: Reply with quote
Starbrite snap and zipper lubricant
You can get quality lift the dot snaps from Sailrite. That is my source. They are easy to set, if you own the proper tools or anvil.
I have let go with "Thataway" a fitting to lift the snaps like Marco linked, but mine had nice teak handles (from an era when teak was cheaper than today).
You might just try a little squirt of "corrosion block" on the inside of the snap. This also is a very good material to prevent corrosion.
Page generation time: 0.0376s (PHP: 62% - SQL: 38%) - SQL queries: 22 - GZIP disabled - Debug on
