bschell
Photos: bschell 2003 22 Cuiser
Posted: Fri Oct 22, 2021 6:09 pm Post subject: Long shot, but you never know |
I know this is a long shot... but some of you whippersnappers are pretty sharp.
I have a 2018 Suzuki DF9.9BTX2 it is used as my kicker and it is a remote installed model, I would be surprised if the engine had 15 hours on it.
The problem:
The engine will idle sweet, but once you put a load on the engine (pushing the boat at 2.5 - 3 mph) the alarm sounds and the RPM's slow down like it is supposed to do at alarm. I have flushed the engine real good, all oil changes are up to date, changed out the thermostat, changed out the impeller. I have taken it to a certified Suzuki shop and there are no error codes or faults, but that darn alarm still comes on. Has anybody run across this frustrating problem? I have not taken it back to the Suzuki shop because they didn't listen to me the first time about the problem... they just call and say your boats ready. |
steveblarson@yahoo.com
Posted: Fri Oct 22, 2021 7:46 pm Post subject: Long Shot |
bschell, I don't have that engine, but have had similar problems. I would suspect three things.
1- The water pump is not operating properly and its overheating. You say you have replaced the impeller so maybe not this? check for a good stream of water coming out of the engine to be sure.
2- Engine is not getting enough fuel. Its getting enough to Idle but not enough under load. Check filters or look for any obstruction that may be preventing proper flow.
3- Air filter, for the same reasons as # 2 _________________ Steve Larson
Currently Hurricane Deck Boat
Seeking C-dory |
Posted: Sat Oct 23, 2021 12:10 am Post subject: |
2018 with 15 hours on it in 3 years. I might also suspect the fuel. If it is a carbed engine, what has been done during off season with the fuel/tank. Emptied and dried -- tank, and carb, or left full with fuel stabilizer mixed in, or just left with a fuel sitting in it from year to year?
SleepyC
bschell
Posted: Sat Oct 23, 2021 11:49 am Post subject: |
It's a fuel injected 2 cylinder engine, I think I will pull the fuel injectors out and clean them. Never done this before... but thanks to you tube I should be able to accomplish the task. If this works? I guess there is no code or fault for dirty injectors. I remember the old days when you could fix anything on your outboard with a flat head screwdriver... Now, you need a team of mechanics a Cat scan machine, AQMD standing by with Hazard suits on! |
DayBreak
Joined: 16 Jul 2017 Posts: 1024 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Sat Oct 23, 2021 5:33 pm Post subject: |
Sounds like a low oil pressure or temperature warning to protect the motor. How long is the shaft? Is it a 20 inch shaft motor and is it submerged in the water enough to cover the cavitation plate while underway? _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
NORO LIM
Photos: NORO LIM
Posted: Sat Oct 23, 2021 6:52 pm Post subject: |
DayBreak wrote: | Sounds like a low oil pressure or temperature warning to protect the motor. How long is the shaft? Is it a 20 inch shaft motor and is it submerged in the water enough to cover the cavitation plate while underway? |
The OP indicates the motor is a DF9.9BTX2, which I believe is the extra long 25 inch shaft. Otherwise, you might suspect the intake is not sufficiently submerged when the kicker is pushing the boat. That would not seem to be the case here. (Unless the motor is mounted unusually high for some reason, like wanting to make sure it tilts enough to prevent it from dragging when the boat is under way with the main engine.) _________________ Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014 |
bschell
Posted: Sat Oct 23, 2021 11:12 pm Post subject: |
Bill you are correct, it is a 25" shaft. There is plenty of lower pick-up in the water... something is getting by the computer scan and not showing a code? |
