Wrong turn=Bad boating day!
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Sun Oct 10, 2021 8:08 pm    Post subject: Wrong turn=Bad boating day! Reply with quote
A 42 foot sailboat (mast stepped) didn’t take the turn into the lock and ended up pinned on the Mississippi River Chain of Rocks near St Louis. The crew was rescued by St Louis Fire/Rescue boats. This mishap is being discussed on the AGLCA forum (open to members only). Local news helo footage:
https://fox2now.com/news/missouri/boaters-rescued-after-vessel-stuck-on-chain-of-rocks/
This link may be moved or deleted.
I hope that detailed info regarding what happened and lessons learned (there are ALWAYS lessons to be learned) come out some day. Tow Boat US reportedly declined to pull the boat off the rocks as an unsafe option; a barge and crane will be required when the water lowers some.
Insurance companies may not cover ‘navigational’ or other skipper errors, just as they may decline to cover a boat that sinks at the dock due to a cracked through-hull as a failure to keep the boat ‘seaworthy’ (as my Progressive policy terms it).
We’ve found lots of instances where following a Garmin Autopilot Route generated by a touchscreen button push could lead to disaster.
The most obvious was a 2018 chip ‘magenta line’ Oswego canal (NY off the Erie Canal) Garmin recommended route that goes over the dam and falls rather than into the lock; this has not been corrected on my 2021 version. NEVER follow an automatic route until you’ve verified it manually. (I’m not implying this skipper did that; I have no facts re that).
We have found many examples over the years where the ‘correct’ route looks like we’re heading into some tiny slough or wrong turn rather than the lock or the correct route.
After some embarrassing and preventable errors, we recommend our current agreement that EITHER of us can offer ‘Hey, I think I’ll veto that for now’...and STOP until we’re BOTH totally satisfied re our situation. We again advise you and your crew to consider that option, if you haven’t already. We didn’t invent it; we learned it from far more experienced cruisers than us and found that it works well for us as well.
Since postings are slow this week, I’ll offer another lesson learned: When moored to a town wall with no security/cipher lock on a river, or in a current, run your dock lines from your boat, through the cleat EYE under the horn of the dockside cleat, then back to your boat to cleat off again on your boat ...rather than cleat off at the town wall. The only downside is that this requires lines twice as long as usual. One upside is that it can make pushing off in the morning easy, since that line can be freed without getting off the boat. That line can also act as a fulcrum point to get off the dock.
The kids don’t carry knives to cut lines and they don’t step aboard boats.
We learned on segment loops over the past few years that there are several areas (including some of our favorite stops) where juvenile delinquents and drunks will untie boats at the town wall cleats, allowing them to drift into the downstream current. Some very experienced Loopers have noted that some boats ended up on the bank in the mud a mile or so downstream, but none have gone over a dam or been injured or killed. However, I can imagine how that COULD happen in some areas. (Again, I am not linking the loss of the sailboat in any way with un-tying of Looper boats from town walls).
One multi-Looper chained his anchor and chain to the town cleat with a padlock with no issues. Others use a smartphone anchor drag app (many available) or drop the anchor (but many of these ancient walls have old rebar, fridges and rusted bikes to hook onto).
Last month, a member of a group of Loopers (8?) posted that they got to the Joliet, IL wall late after a long day and tied off. At 2AM, one skipper woke to shouting and found a lady busy un-tying boats, and they had a shouting match which awoke some but not all of the others. One boat drifted out into the current with only his shorepower cord securing his boat to shore; the boat behind him caught that boat with a boat hook.
Several boats were using the ‘cleat only on the boat and never to the shore’ method, and they weren’t touched.
Comments invited…
Hope these suggestions and observations are helpful to you and your crew!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
PostPosted: Sun Oct 10, 2021 8:42 pm    Post subject: Reply with quote
Perhaps the lady untying the boats should have been pulled into the water and dragged along like a sea anchor for a little ways! In my grouchy old age I have no more time for idiots like that! Regarding the sail boat, I've been through that Chain of Rocks canal a few times. I suppose if one wasn't paying attention to the chart notes or familiar with the area, it might not be that hard to stay in the main channel. The main channel heads off to the starboard side, while there is a big signboard pointing out the canal on the port side. I'm not sure where the dam is there since I've never chose to check out the rapids. Mr. Green There is a lock in the canal, so I suppose the dam is near there. Looking at Navionics, there is even a note that says navigation not recommended due to low water dam and low vertical bridge clearance. Actually, while looking at my navionics, I see that dam on the main channel is a bit farther upstream from where the lock is on the canal. And all the nav aids, if you are following them, take you into and down the canal. While I like my garmin chips that allow for routing guidance, I find too many times it doesn't route in the navigable channel!
PostPosted: Mon Oct 11, 2021 3:05 pm    Post subject: Reply with quote
I have zero desire to do the “Great Loop”. Big cities, dirty water, rivers...yuck. The entire mid-west portion of the route, to me, has nothing that attracts me. Give me a white sand beach or a quiet cove any day. I’ll do the ICW, the Gulf etc, but the Mighty Mississippi is not my cup of tea.
PostPosted: Mon Oct 11, 2021 4:54 pm    Post subject: Reply with quote
localboy wrote:
....The entire mid-west portion of the route, to me, has nothing that attracts me. Give me a white sand beach or a quiet cove any day. I’ll do the ICW, the Gulf etc, but the Mighty Mississippi is not my cup of tea.
I don't know. I was watching a program the other day about the Mississippi. The upper part looked pretty nice.
PostPosted: Mon Oct 11, 2021 5:51 pm    Post subject: Reply with quote
We have done the upper part of navigable Mississippi, and the St. Croix Rivers. Also the Cumberland and Tennessee rivers in their navigable entirety
There were not problems with vandalism at the docks. There a number of really great places on the heartland rivers.
Same for St. John's River.
We didn't get the do the Erie Canal this year, but that is life. Maybe, it was fate not to take on these "dangerous waters" frequented by the ":Loopers"
PostPosted: Tue Oct 12, 2021 1:00 am    Post subject: Reply with quote
Well, I figured if Tom Sawyer could do it on a raft it can't be tooo hard, Then again, he wasn't in a 40ish sail-cruiser.
PostPosted: Tue Oct 12, 2021 9:38 pm    Post subject: Reply with quote
Each to his own cup of tea I guess. We loved the Atlantic ICW, the Chesapeake, the New Jersey ICW, the Hudson, the Erie Canal, the Trent Severn Waterway, Georgian Bay, the North Channel, Mackinac Island and Lake Michigan.
But we also really enjoyed the cruise from Chicago to Mobile too. There were a lot of cool stops on the Illinois River, and the really only nasty spot on the Mississippi was Boston Bar, just before we started up the Ohio (about 30 miles). We were only 14 days out of Chicago on the Illinois and Mississippi before we were at Green Turtle Bay and Kentucky Lake, which is spectacular. Pickwick Landing State Park is also very cool. At Aqua Yacht Harbor we entered the Tenn-Tom Waterway, and had a fun cruise to Mobile, although there were some tense moments when we went up the Alabama River to anchor for the night and Baxter got his leash tangled around a tree. I had to go untangle him in alligator territory! But these are all WONDERFUL memories for us, and we would not have missed it for the world!
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
PostPosted: Tue Oct 26, 2021 9:34 pm    Post subject: Reply with quote
Update:
The owner of the Hunter 44 sailboat was interviewed in the St Louis Post Dispatch and admitted that he made a ‘wrong turn’, missing the channel into the lock.
His insurer, Progressive (mine also) after 3 weeks would not commit to a salvage op for crew safety reasons, after paying for a barge and crane coming up from FL to do the job.
After heavy rains, the river rose 8 feet and the boat disappeared over the 10 ft wing dam and is presumed sunk in 30ft of the river.
I’m sorry that the 63 yo retired Marine and business owner who dreamed of living on his boat on a Bahamas voyage with his ‘girlfriend’ had his dreams so violently dashed.
He claims that there were no orange buoy cable boat ‘catchers’ or other warnings that he was taking the wrong course.
After 200 locks and dams, we can not name one that did not have orange warning buoys and boat catcher cables that would catch a boat before it goes over a dam, rocks or water falls. On the other hand, the Mississippi is a giant river compared to the ones we’ve cruised so far.
We hope you and your crew learn something from this mishap.
Localboy: we agree with Pat that the Loop waterways are for the most part not ‘dirty’. You can see down 30 feet on the crystal clear St L and Lake Champlain and much of the Canada historic canals. Come out and see them, you’ll love it!
PostPosted: Tue Oct 26, 2021 10:47 pm    Post subject: Reply with quote
Hi John,
I've been on the Chain of Rocks canal and lock. But since I haven't gone down the other main river channel, I have no idea if there are orange buoys or lines there or not. I can say that most locks and dams on the Mississippi River do not have warning orange buoys or boat catching lines. Most have a big sign by the lock that basically says do not approach the dam closer than 500 feet, and there may be a few white warning buoys across the river marking that distance. And in fact, there have been a number of boats and barges that have gone across the dams. Also, during our Great Mississippi River trip Pounder put together last month, we had to wait a few hours at Lock 3 as they shut it down while doing a recovery operation for a fisherman that got to close to the dam on the downstream side. The undercurrents can actually be worse, making the dam more dangerous on the down stream side. Back to Chain of Rocks, I do remember there is one big sign on the point of land between the main channel and the canal that points out the locks to the left. To be honest, seems that I remember thinking the first time I was there I thought it odd that there really wasn't any other signage or warning about going down the main channel. I could be wrong in my memory, it's been a couple years since the last time I did that section. However, there are plenty of warnings in charting. So I guess in that regard I can't necessary blame the guy for going the wrong way, particularly if he wasn't familiar with the area.
I'll add my two cents to LocalBoy's comments about Midwest boating as well. These are trailerable boats. Some of you's all need to get out of your own back yards! The PNW has some beautiful boating. However, I wouldn't dis the beauty of many of the Midwest's lakes and rivers. And we don't have salt, tides or sharks! Mr. Green Colby
LesR
City/Region: St. Louis
State or Province: MO
Vessel Name: Intuition
Photos: Intuition
PostPosted: Wed Oct 27, 2021 9:55 am    Post subject: Reply with quote
And now it's gone...
https://fox2now.com/news/missouri/boat-stuck-on-mississippis-chain-of-rocks-gone/
Apparently storms that went through the area Sunday dislodged the boat from the dam. The dinghy was found downstream, but not the boat.
Les and Kel Rohlf
PostPosted: Wed Oct 27, 2021 11:30 am    Post subject: Reply with quote
Expensive mistake.
Page generation time: 0.0471s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
