Davit for lifting
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Thu Sep 30, 2021 11:19 pm    Post subject: Davit for lifting Reply with quote
Looking at the St Croix 488 rotating davit for mounting one on the gunnel for lifting a dingy onto the roof. I’ve found a set of 2 for sale and would use 1.
What does everyone think? Would it work?
https://www.davit.com/rotating.html
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Fri Oct 01, 2021 9:38 am    Post subject: Reply with quote
Those look like there made for the stern. Doesn't look like they would rotate far enough to put the dingy on the roof.
Jody Kidd
KE7WNG
Northern, Utah
kaelc
Photos: Stil-Afloat
PostPosted: Fri Oct 01, 2021 11:09 am    Post subject: Reply with quote
Thanks @jkidd what brand and model is yours? Looks great
jkidd
PostPosted: Fri Oct 01, 2021 2:50 pm    Post subject: Reply with quote
https://www.garhauermarine.com/transom-hardware-accessories/lifting-davits/lifting-davit-engine-hoist-ld-6-1-m-long.html
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Fri Oct 01, 2021 3:19 pm    Post subject: Reply with quote
If you type "garhauer" in the search box at the top of the page, you will find loads of information in various threads.
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
PostPosted: Fri Oct 01, 2021 7:47 pm    Post subject: Reply with quote
Here is a link to photos of the Garhauer Davit which I have put on 4 C Dorys.
Catskinner
C-Dory Year: 2022
Vessel Name: Dock Holiday
Photos: Dock Holiday
PostPosted: Sun Oct 10, 2021 1:39 pm    Post subject: Garhauer davit Reply with quote
Bob,
What did you come up with regarding optimum height for your davit? I’m trying to put 2 Hobie revo 13’s on the roof of my 26’ venture and then a 9’ dinghy on top of those.
Tia, CS
PostPosted: Sun Oct 10, 2021 2:57 pm    Post subject: Re: Garhauer davit Reply with quote
Catskinner wrote:
Bob,
Tia, CS
I used to own a 13 Revolution, and my current inflatable is a 9.5' air floor with 15" tubes. On our C Dory 25, we added 12" to the base tube. That was enough to get the boat just to the cabin top level--and then slide it up onto the top, with minimal weight on the cabin. I had been thinking about putting the spreader bar lower, and at the point of balance. (it is about 3" off, utilizing the D rings which were already in the boat.
Also we don't know if you are going to use a rack, or just some padding under the kayak directly on the roof structure.
I advise adding 24" for most boats. The problem is I don't know how "tall" Garhauer will make the lower support tube. I also don't know what point you will use to attach the Rev. to the spreader bar.
If Garhauer will allow 30", that is where I would be just eyeballing what is necessary.
Let us know how it works out.
Catskinner
C-Dory Year: 2022
PostPosted: Sun Oct 10, 2021 3:21 pm    Post subject: Reply with quote
Thank you Bob! I think I’ll give them a ring next week and see what they will do.
Catskinner
C-Dory Year: 2022
PostPosted: Mon Oct 11, 2021 8:00 pm    Post subject: Reply with quote
The answer was I’ll make whatever you want, if anyone is interested!
pelkie123
City/Region: Bellevue
PostPosted: Wed Dec 07, 2022 12:06 pm    Post subject: Here's a davit system that Ranger boats use: Reply with quote
https://cruisingodyssey.com/2020/08/11/new-dinghy-lift-for-outboard-powered-ranger-tugs-27/
John H.
PostPosted: Wed Dec 07, 2022 5:15 pm    Post subject: Re: Here's a davit system that Ranger boats use: Reply with quote
It is kind of a kludge IMO. You could do something similar on a C-Dory if you really wanted to.
PostPosted: Wed Dec 07, 2022 6:52 pm    Post subject: Reply with quote
I had looked at that system, and my conclusion was that you needed two rather long swim steps, which went beyond the outboard. Would that be practical for the C Dory line? Also there is already a swim step/outboard bracket involved for the outboard. The mechanism is a but crude with the winch which has to be put on the gunnel etc. There would be easier and smoother ways to do that part of it using a small electric winch.
I had a system which pulled a 12 1/2' RIB with 25 hp (Weight in the 370# category) over the transom of my Cal 46, like a "pull boat" on a purse seiner, with an electric winch--smooth and about a minute to either retrieve or launch even when under way. That type of system might be developed as part of a frame, rack over the cockpit of the C Dory 22 or 25, instead of a Bimini. I know of some 22s which carry the dinghy on a rack over the cockpit--but I don't believe any of them are motorized.
Page generation time: 0.1488s (PHP: 64% - SQL: 36%) - SQL queries: 30 - GZIP disabled - Debug on
