16 Cruiser Prop
kcohen4
City/Region: WILLIAMSBURG
Vessel Name: Annie M.
Photos: Annie M
PostPosted: Sat Sep 25, 2021 4:55 pm    Post subject: 16 Cruiser Prop Reply with quote
I just dinged my prop!!
Need a replacement so thinking now is the time to get something better.
I have a 2019 Yamaha 50 Old prop was 13 1/2 X 15K
Aluminum
Max rpm 5000 = 30 mph
Any thoughts?
2004 16 Cruiser with 2019 50 Yamaha
1984 Grand Banks 36
1984 Boston Whaler 13
1982 CC Landfall 38
1979 Catalina 27
Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
PostPosted: Sun Sep 26, 2021 1:41 am    Post subject: Reply with quote
Just FYI: Props can also be repaired.
OR,
You could still get a new one in addition to this one being repaired, and then use it as a spare.
Current boats:
1988 16' Angler - "E-fishn-C"
Also:
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Sep 26, 2021 12:57 pm    Post subject: Reply with quote
If you're getting 30 mph with this one, you're doing real good with this size prop. Stick with this size and maybe slow down.
MartyP
kcohen4
Photos: Annie M
PostPosted: Sun Sep 26, 2021 4:37 pm    Post subject: I have a new Yamaha 50 on my 16 cruiser Reply with quote
Not really looking for more speed but better efficiency
would a 15 1/4 X 17 allow higher RPM that the 15 1/2 X 15?
kcohen4
Photos: Annie M
Wood Zeppelin
C-Dory Year: 1997
PostPosted: Mon Sep 27, 2021 6:10 am    Post subject: 30mph!? Reply with quote
Holy Cow (30mph!)
I get about 24-26 tops in my 16' cruiser with a Honda 40. I don't know my prop specs. I do get excellent mileage.
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon Sep 27, 2021 3:31 pm    Post subject: Reply with quote
15 1/4 x 17 would probably give less speed and reduced rpm = less efficiency
kcohen4
Photos: Annie M
PostPosted: Mon Sep 27, 2021 4:21 pm    Post subject: Reply with quote
Sounds like I will buy the same as I had 13 1/2 x 15 for the replacement. Guess I just got lucky as that was what came with the motor.
chieftele
City/Region: Placerville
Vessel Name: Rose Bud
Photos: Rose Bud
PostPosted: Mon Sep 27, 2021 11:09 pm    Post subject: Reply with quote
My 16 Angler maxes out at 24 mph with me, the wife, and an ice chest, at low elevation. About 5200 rpm, but I don't remember the specs of the prop. I actually had the pitch reduced by a prop shop shortly after I got the boat.
kcohen4
Photos: Annie M
PostPosted: Fri Oct 01, 2021 5:22 pm    Post subject: Reply with quote
received a new Solas prop 13 1/2" X 15
Now highest rpm is 4400 and top speed is 24mph
This is exactly the same size as the original Yamaha. I lost 600 RPM and 6 MPH?
Solas is sending me a 14" X 11 pitch. Will this get me in the right direction.
I noticed the blade shape of the Aluminum Yamaha is slightly different that the blade of the Aluminum Yamaha. Went with the Solas as I thought that might be a upgrade.
Any thoughts?
dotnmarty
Photos: Lizzie
PostPosted: Fri Oct 01, 2021 8:29 pm    Post subject: Reply with quote
Personally, I think your motor is better off at 4400 rpm and you are safer at 24mph. Just my take.
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Fri Oct 01, 2021 9:12 pm    Post subject: Reply with quote
4400 rpm is taxing the motor. It needs to be able to turn the 5200 or so rpm, even if you do not run it there. Perhaps the new prop you have on order will do it. Hopefully it will not allow too high revs
Page generation time: 0.0383s (PHP: 63% - SQL: 37%) - SQL queries: 29 - GZIP disabled - Debug on
