pcg
Vessel Name: C-Quest
Photos: pcg
Posted: Fri Aug 27, 2021 1:00 pm Post subject: Diesel outboard |
100 hp, 381 lbs. - That all sounds great, but I wonder about the price.
https://www.klaxondieseloutboards.com/ _________________ Paul |
Joined: 27 Oct 2012 Posts: 3387 City/Region: SW Michigan
Posted: Fri Aug 27, 2021 2:01 pm Post subject: Re: Diesel outboard |
100 hp (EUD100) = 210 Kgs = 462 lbs. |
pcg
Photos: pcg
Posted: Fri Aug 27, 2021 4:52 pm Post subject: Re: Diesel outboard |
ssobol wrote: |
Ahh yes, you are correct. I had scrolled to the bottom of the page and inadvertently read 173 kg- the weight of the 60hp motor. |
Posted: Fri Aug 27, 2021 6:03 pm Post subject: |
The diesel 80 hp is $16,000, plus shipping. If that price holds then it would be competitive price wise with a gas outboard. _________________ Bob Austin
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Sat Aug 28, 2021 11:13 am Post subject: |
If the price of them really gets down to gas repower land, or even just a 1/4th or so more, and they have good fuel burn numbers and proven longevity, then you're going to see lots of them hanging on the back of boats. |
Posted: Sat Aug 28, 2021 11:47 am Post subject: |
T.R. Bauer wrote: | If the price of them really gets down to gas repower land, or even just a 1/4th or so more, and they have good fuel burn numbers and proven longevity, then you're going to see lots of them hanging on the back of boats. |
Going to take awhile for them to be enough fielded and for long enough to demonstrate longevity. Just because it's a diesel, doesn't mean it will last any longer than a gas engine.
Those old cast iron diesels that are relatively low hp/lb last forever because they are under pretty low stress (for an engine). The small high power diesels don't last as long. All the high tech stuff on modern diesels also are where a lot of the problems occur, not with the stuff inside the block.
The diesel outboard in this thread seems to have a more complicated output and cooling setup than a typical gas O/B. Wonder if there'll be some trouble there. |
T.R. Bauer
Posted: Sat Aug 28, 2021 6:00 pm Post subject: |
ssobol wrote: | T.R. Bauer wrote: | If the price of them really gets down to gas repower land, or even just a 1/4th or so more, and they have good fuel burn numbers and proven longevity, then you're going to see lots of them hanging on the back of boats. |
You're not wrong.....make no mistake I'm not getting one any day soon |
