80's 16' angler window
Bobberdown
City/Region: Olympia
Vessel Name: G.S. lollipop
Photos: Bobberdown
PostPosted: Wed Aug 18, 2021 12:50 pm    Post subject: 80's 16' angler window Reply with quote
I have an early 80's angler 16' the sliding window on the passengers side is no longer there, anyone know if there is somewhere to get a replacement? Backup plan is to pull drivers side and use it as a template to have the other cut.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Wed Aug 18, 2021 1:02 pm    Post subject: Reply with quote
Bobberdown,
The OEM product was most likely Diamond Sea Glaze in Canada. You can request repair parts here:
https://www.advantecstore.com/Brand_DSG
The cost to do business with them is extremely expensive. The alternative is to have your local glass shop replace the OEM window.
I recently had three forward windows made and installed. I do most things on my own, but the cost of safety glass, even before cutting it is expensive, so I had my local glass shop do the project and I was very pleased with the finish work.
Steve Baum
Homeport of Portsmouth, VA
Bobberdown
Photos: Bobberdown
PostPosted: Wed Aug 18, 2021 1:49 pm    Post subject: Reply with quote
thanks for the heads up. I am in Olympia, WA, and would like to find a direct fit/replacement. Anyone have any recommendations for who does this around here
PostPosted: Wed Aug 18, 2021 1:58 pm    Post subject: Reply with quote
Diamond Glaze supplies tempered glass, the same as used in your side and rear car windows. It crumbles when it breaks, or at least mine did. At least they did for Journey On, a 2005. The front of your car uses safety glass, which has a thin layer of plastic between 2 sheets of glass.
When you go to your local good glass shop, ask for safety glass. It's cheaper, less trouble and if it's good for a windshield it's good for a C-Dory window.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Thu Aug 19, 2021 11:54 pm    Post subject: Reply with quote
I pulled my good one out and took it to a Seattle shop that I had dealt with in the past. They didn't carry the required tempered glass in stock and sent it out to a shop in Tacoma (I learned after looking at the work order). Can't remember the name now, but you might do some research and find out who they are. I remember it was pricier that I was hoping for. Don't know if that was a markup or just that tempered glass is expensive.
Mark
Page generation time: 0.046s (PHP: 38% - SQL: 62%) - SQL queries: 18 - GZIP disabled - Debug on
