SOLD - 2005 C-Dory 22 Cruiser, Hightop, SE Michigan
little wing
City/Region: Oakland
Vessel Name: Toots
Photos: Toots
PostPosted: Sun Jun 20, 2021 2:45 pm    Post subject: SOLD - 2005 C-Dory 22 Cruiser, Hightop, SE Michigan Reply with quote
Health issues finally got to me. Toots is for sale. $42k
2005 C-Dory 22 Cruiser, hightop (6’6” headroom), freshwater, bottom never painted
2005 Suzuki 90hp, 460 hours
2003 Nissan 9.8hp 4 stroke, mounts directly on transom, includes coupler to main engine
2005 EZ Loader trailer, galvanized, two axle, electric brakes, tires dated 0617
Factory removable fiberglass cockpit floor panels
Swim platform and boarding ladder
2x 25 gallon fuel tanks
20 gallon fresh water tank
Delta Fast-Set anchor, 14#, 10ft chain, 150ft 8plait
Guardian (Fortress) aluminum fluke anchor, 4#, 6ft chain, ?ft 3 strand
Simpson-Lawrence Sprint 600 vertical windlass
Permatrim on Suzuki 90
Bennett trim tabs with indicator
2 batteries in starboard lazarette, group 24 wet and group U1 agm
Michigan Match aluminum 3 blade 14 dia x 19 pitch propeller (currently on the 90)
Solas HR Titan stainless 3 blade 13-⅞ dia x 17 pitch propeller
Aluminum 3 blade 14 dia x 17 pitch
Spare prop for nissan 9.8
Garelick 4 step telescoping stainless boarding ladder, hangs on gunnel, 400# rated
Bimini, high clearance to match high top interior, extends over splashwell
Shurflo 12V fresh water pump plumbed to sink faucet and cockpit hose bib
Electric windshield wipers
Sunbrella window coverings, roll-up
Door screen, roll-up
Dometic 965MSD porta potty, not used
Ports, opening, x2, in v-berth
Keel guard
Anchor locker sealed off from v-berth with hatch cover opening
Passenger side v-berth bulkhead cut out
Splash well filler / cooler support
V-berth filler and cushion
Bow mounted boarding ladder
Caframo 2-speed fan, x2
Single burner portable dual fuel stove, butane/propane
Ritchie compass
Added hand grips on cabin top and at swim platform
Added hand grips overhead in cabin and over v-berth entry
Storage under v-berth both sides
30A shore power
Guest 10A onboard battery charger
Lines, dock and spring
Fire extinguisher, x2
LED interior lights and LED anchor light
Fenders, x7
Engel 35 rotomolded cooler
Scotty rod holder
3 gallons full synthetic motor oil for Suzuki 90, unopened
Tekonsha PrimusIQ brake controller (need vehicle connector)
ELECTRONICS
Garmin EchoMap Plus 74cv, 2019
Standard Horizon GX1400GPS VHF fixed mount radio, 2019
Icom IC-M36 handheld VHF 6watt radio
Raymarine SL72 Plus Pathfinder Radar and display, removed to put dinghy on roof
Uniden Oceanus DSC VHF fixed mount radio, no longer installed
Dual MXD340SXM digital media receiver w/ SiriusXM Tuner and antenna
DINGHY
Zodiac Cadet 230 Aero, 2020, 7’7”, 53#, high pressure floor, roll-up
Suzuki 2.5hp short shaft, 2020, 29# (currently the kicker)
Garelic adjustable mount for 2.5hp motor (currently mounted on transom)
12v inflator
DOESN’T WORK
Suzuki speedometer and depth sounder
Fuel flow meter works occasionally
NEEDS WORK
I don’t do ladders well anymore, so...
Foredeck hatch developed a drip last fall. It should probably be rebedded. I’ve got the 4000.
Roof could use a good cleaning and wax
GENERAL COMMENTS
All engines run excellent
No hull damage or repairs
Everything works
Previous owner did a lot of nice custom upgrades. Thanks Bob K.
Bruce
brucestevens55@gmail.com
little wing
Vessel Name: Toots
Photos: Toots
PostPosted: Wed Jun 23, 2021 3:14 pm    Post subject: Reply with quote
Sale pending.
little wing
Vessel Name: Toots
Photos: Toots
PostPosted: Wed Jun 23, 2021 3:23 pm    Post subject: Reply with quote
Sale pending.
little wing
Vessel Name: Toots
Photos: Toots
PostPosted: Sun Jun 27, 2021 2:22 pm    Post subject: Reply with quote
Sold
Page generation time: 0.1112s (PHP: 91% - SQL: 9%) - SQL queries: 22 - GZIP disabled - Debug on
