clayhubler
Joined: 03 Aug 2019 Posts: 286 City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
Posted: Thu May 27, 2021 1:58 am Post subject: Interior cabin paint |
I was surprised to see the interior of the cabin is painted. For some reason I had assumed it was gelcoat also. I am going to need to patch a bunch of areas in the cabin. Does anybody know what type of paint was used? Does it matter what type of paint I use to repaint in the cabin?
Thanks! _________________ Clay on Hammerhead
Ferg
Joined: 18 Jun 2015 Posts: 187 City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
Posted: Thu May 27, 2021 5:22 am Post subject: |
My cabin had a few chips, so I took one to the Spectrum Paint store, and they did a perfect color match. They said “PPG Breakthrough” will stick to anything, and it certainly did. It was a satin finish.
Although the painted area blended in perfectly, later on, I painted the entire cabin. It looks fresh and new |
Joined: 27 Oct 2012 Posts: 3396 City/Region: SW Michigan
Posted: Thu May 27, 2021 11:31 am Post subject: |
I painted mine with paint from Home Depot. Satin finish. Makes the interior much nicer.
Barry Rietz
Joined: 21 Jun 2006 Posts: 412 City/Region: Sierra Vista
Posted: Fri May 28, 2021 12:03 am Post subject: Interior Paint |
Clay; FYI, most of the newer water based paints contain properties that resist mildew and mold. It would be best to thoroughly clean all surfaces you intend painting first until you have sufficiently removed all residues. It might also be wise to lightly sand with 200 grit paper the areas you intend painting to provide a "tooth" the paint can stick to. _________________ Barry Rietz
N9DXC |
