Moisture meter help
iyaman
Vessel Name: Eye C Fish
Photos: Eye C Fish
PostPosted: Fri Jun 11, 2021 12:24 am    Post subject: Moisture meter help Reply with quote
So I got a klein tools moisture meter. So what's the acceptable percentage of moisture reading and what reading should I start to worry?
I see softwood, hardwood, masonry and drywall mode. What's the best mode to use when taking a reading on our C-Dory?
Thank you all.
consistently inconsistent
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
PostPosted: Fri Jun 11, 2021 2:09 am    Post subject: Reply with quote
iyaman,
I have a meter like this and I assume yours is similar
I used mine on hardwood at first, but the drywall and masonry settings go to 100% while hardwood only goes to 35%. It doesn't really matter too much, the readings are all relative. The best way to use one of these meters is to find an area that is cored that you know is dry and take a reading and use it as a baseline. If you one area with a much higher reading than another then it is time to take a closer look. You can see in the picture above a reading of 16% and in the pic below 0%. The deck fitting in the first picture was leaking and the coring was wet and starting to rot.
Remember that the meter is using conductivity to measure the moisture content. So metal really close or behind can give a false reading. Also, the surface needs to be dry. I have also heard that bottom paint with copper in it can affect the reading. And I think the meter only reads down about 3/4" or so.
Also, I wouldn't tear anything apart unless you get high readings and have another reason to suspect water intrusion.
Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser
iyaman
Photos: Eye C Fish
PostPosted: Fri Jun 11, 2021 9:42 pm    Post subject: Reply with quote
Thank you Clayhubler.
Page generation time: 0.0357s (PHP: 57% - SQL: 43%) - SQL queries: 20 - GZIP disabled - Debug on
