One of these things is not like another, one of these things
Nancy and Bud
City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
PostPosted: Tue Jun 08, 2021 1:18 pm    Post subject: One of these things is not like another, one of these things Reply with quote
doesn't belong.
I bought two new hatches for the stern.
Removed the starboard one first, no problem. Removed the port one to find that the screws had leaked on the forward end, balsa core rotted. Grrrr.
The new port covers the screw holes so that shouldn't be a problem in the future.
If you have nothing to do, buy a boat.
"C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine
Yakmandu
City/Region: Lake Lanier
State or Province: GA
C-Dory Model: 19 Angler
Vessel Name: Miss April
Photos: Pops GO!
PostPosted: Tue Jun 08, 2021 1:33 pm    Post subject: Reply with quote
Another project on my list! Can you share the manufacturer and part number please?
Patrick Rohde
Miss April
Lake Lanier, GA
Nancy and Bud
Photos: Emma Mae
PostPosted: Tue Jun 08, 2021 1:37 pm    Post subject: Reply with quote
Happy to share.
So-Pac Marine® - 4000 Series 325 mm x 255 mm White Access Hatch
https://www.boatid.com/so-pac-marine/4000-series-325-mm-x-255-mm-white-access-hatch-mpn-spa-40155.html
PostPosted: Tue Jun 08, 2021 2:14 pm    Post subject: Reply with quote
That is one of the first things I did on SleepyC, way back when Joel was ordering them from the mfg by the case load. Worth every penny and the effort.
SleepyCMoon
Chester
City/Region: home
Photos: Chester
PostPosted: Tue Jun 08, 2021 3:18 pm    Post subject: Reply with quote
I've used an aquarium pump to blow air in after digging out all the wet core I could.
It doesn't need a big breeze, just enough to keep fresh air moving. Sunshine, a heat lamp or something to warm the surface helps too.
PostPosted: Tue Jun 08, 2021 4:00 pm    Post subject: Reply with quote
Based on what I read on this site, changing the lazarette hatches was the first thing I did to my boat when I bought it.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Jun 08, 2021 4:02 pm    Post subject: Reply with quote
Nancy & Bud,
I did the job on my 22 and more recently on my 26. I had no rot around the 22 hatch, but some on the 26. I only had to dig out about 1 inch around the perimeter, wetted it out with epoxy, then used thickened epoxy to finis filling the void. I had to make up a bit of difference in the new hatch dimension, so did that with wood and epoxy.
I purchased my first set of hatches through Defender and the second set through West.
http://www.c-brats.com/modules.php?set_albumName=album2901&op=modload&name=gallery&file=index&include=view_album.php
Steve Baum
Homeport of Portsmouth, VA
Nancy and Bud
Photos: Emma Mae
PostPosted: Tue Jun 08, 2021 5:35 pm    Post subject: Reply with quote
Thanks for the album link
Page generation time: 0.0395s (PHP: 62% - SQL: 38%) - SQL queries: 25 - GZIP disabled - Debug on
