Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Fri May 07, 2021 7:52 am Post subject: Gauges don’t work.... |
I have had low voltage at the fuse panel. So I started at the battery and cleaned the connections, then clean all the grounds behind the dash & now have full voltage. Then I replaced original fuse panel with same but new, added additional blue sea box for things that had in line fuses. Now everything seems to work, voltage is good......but none of my gauges work....don’t know where to start?? _________________ 1991 C-Dory 21’ Pro-Angler |
Joined: 02 Nov 2003 Posts: 20813 City/Region: Pensacola
Posted: Fri May 07, 2021 8:17 am Post subject: |
Did you check the wiring harness at the motor as well as at the panel? What outboard engine do you have? These contacts can also corrodel. Does the motor start and run well? Does the tachometer register? _________________ Bob Austin
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Fri May 07, 2021 9:00 am Post subject: |
The volt meter & tach did work before I started messing around, but not now. 2004 Honda 90 & runs perfectly. |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Fri May 07, 2021 3:14 pm Post subject: |
I don’t think it would be at the engine as I suspect it was something I did....but I think all wires are accounted for. Is there a fuse for the panel??? |
gulfcoast john
Joined: 14 Dec 2012 Posts: 989 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Fri May 07, 2021 6:39 pm Post subject: |
Gary,
I had the same experience on my boat. At the time I was not familiar with this chart:
http://www.criboats.com/wp-content/uploads/2015/04/Outboard-Wire-Colors.pdf
Try to trace your yellow/green (temp gauge sender) and gray (tach) [under the Honda column in this chart] from your helm instruments as far back as you can. Mine led to blown inline 10A fuses at the binnacle end of the engine wiring harness. They were WAY back near the throttles and almost inaccessible in my boat. I don’t have an access plate back there.
The circuit protection for all my helm wiring is a 40A breaker on the 12v distribution/battery selection switches back on the transom, not a fuse.
At the time, I knew that under modern rules 12V NEG wires could be black (old std) or yellow (new std), but I did not know that in YamaWorld yellow was IGN ON 12V POS as per this chart. Yet further proof, should you need any, that A LITTLE KNOWLEDGE CAN BE A DANGEROUS THING!
Hope this helps, and also that you have at least one arm that is 6 feet long with a hand that can replace the fuse in an inline fuse holder with three fingers by feel.
Best,
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
digger
Vessel Name: C-Sik
Photos: Snoopy-C
Posted: Fri May 07, 2021 6:48 pm Post subject: |
The tach wires come from a plug on the binnacle control box. There are usually 3 or 4 wires there, and sometime can pull apart when you are working on wires under the fuse panel. |
digger
Vessel Name: C-Sik
Photos: Snoopy-C
Posted: Fri May 07, 2021 6:49 pm Post subject: |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Sat May 08, 2021 10:16 am Post subject: |
Thanks gulfcoast john, digger, thataway..... I’m going back in! 😳
.....I had to look up binnacle control box! 🤣🤣🤣 |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Sat May 08, 2021 11:40 pm Post subject: |
It looks as if they are using the studs are attachment points. Is the base a plastic or aluminum? The wiring is not consistent with ground black and positive red. It looks as if at least one jumper for the positive is black. If that happens, I usually replace with a proper color, or wrap red tape over the black wire--or red head shrink by the fittings.
Glad the problem was solved...!! |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Joined: 27 Oct 2012 Posts: 3374 City/Region: SW Michigan
Posted: Sun May 09, 2021 12:06 pm Post subject: |
Looks to me like a sensor of some kind. Don't know what though. I would undo the tie and see if it said anything on it. I'd also look into the shop manual for the engine you have and see what is says about the remote controls and indicators. |
tsturm
Joined: 01 Nov 2003 Posts: 1134 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun May 09, 2021 9:45 pm Post subject: |
A capped off connector, a diode. LOOK? |
BBlalock
Joined: 31 Jan 2017 Posts: 140 City/Region: Ocean/ICW
C-Dory Year: 2013
Vessel Name: Finale
Posted: Mon May 10, 2021 11:19 am Post subject: |
Gary, when I lost power to my switch panels I learned the Accessory fuses(2) run them. I don't know if the gages were affected though. _________________ '13 25' Cruiser "Finale"
'12 22' Fiesta pontoon(sold) |
