Fuel fill bonding wire
clayhubler
City/Region: La Center
Vessel Name: Hammerhead
Photos: Hammerhead
PostPosted: Mon Jun 07, 2021 1:27 am    Post subject: Fuel fill bonding wire Reply with quote
Hello Brats,
Question about the fuel fill. My boat did not have a ground wire attached to the deck fill when I took it apart. My last boat did. I know the wire is to prevent a static spark from causing an explosion when filling up.
So, why no grounding wire on the deck fill of the c-dory?
My tanks are all plastic, including the filler neck. Not sure if that matters.
Thanks all!
Clay on Hammerhead
clayhubler
Photos: Hammerhead
PostPosted: Thu Jun 10, 2021 11:25 pm    Post subject: Reply with quote
Anybody have a bonding wire on their deck fill?
Barry Rietz
City/Region: Sierra Vista
PostPosted: Sat Jun 12, 2021 11:24 pm    Post subject: Fuel Fill Ground Wire Reply with quote
Clay, "Most" fuel dispenser nozzles that are for public use are bonded (grounded) internally. However, that does not mean all static electrical sparks are prevented from occurring. Because our small boats are not required to have bonding throughout the vessel, the factory does not install this type of fire prevention system. Careful is the word, especially in the dry hot climate we are now experiencing!
Barry Rietz
N9DXC
clayhubler
Photos: Hammerhead
PostPosted: Sun Jun 13, 2021 1:35 am    Post subject: Reply with quote
Thanks. I have decided to install one for piece of mind. Thumbs Up
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Sun Jun 13, 2021 3:09 am    Post subject: Reply with quote
What will you bond it to?
Paul
clayhubler
Photos: Hammerhead
PostPosted: Sun Jun 13, 2021 10:52 am    Post subject: Reply with quote
Any negative bus should work as far as I know.
PostPosted: Sun Jun 13, 2021 12:00 pm    Post subject: Reply with quote
On the 25 C-Dory, the fuel fills are aluminum, which as far as I know, don't spark, though they conduct electricity. I don't know about the 22, but I'm willing to learn.
With the grounded fuel nozzle, is there any chance of static electricity making a spark with the ungrounded fuel fill? I'm curious.
kaelc
City/Region: Saanich
Vessel Name: Island Magic
Photos: Stil-Afloat
PostPosted: Mon Jun 14, 2021 8:58 pm    Post subject: Reply with quote
Yes, our 25 has a grounding wire. The screw was rusted so we replaced it and had to reattach the wire. Keep a couple lock nuts handy and dialectic grease. I dropped a couple nuts it’s as difficult reach in there.
Page generation time: 0.1206s (PHP: 89% - SQL: 11%) - SQL queries: 27 - GZIP disabled - Debug on
