[Q] Can I tow a 22ft SD with a V8 4Runner?
pelkie123
City/Region: Bellevue
PostPosted: Thu May 20, 2021 2:58 pm    Post subject: [Q] Can I tow a 22ft SD with a V8 4Runner? Reply with quote
I am assuming the 22ft SD uses a tandem trailer. Not sure what the towing weight would be for that rig.
My 2006 V8 4WD 4Runner is rated for 7000 lbs towing and has a 4.7 V8 with good power.
If I used a tandem trailer with electric brakes and a WDH, - would that be a safe rig for highway?
Otherwise, I assume an F150 is adequate.
[Q] Anyone towing a 22ft SD with a 4Runner?
Bellevue, WA
John H.
PostPosted: Thu May 20, 2021 3:39 pm    Post subject: Reply with quote
You should be fine with the ratings. Rigs weight from 4,000 up to over 5,000 with trailer. Some have single axle--better for road trailer to have dual axle. I prefer electric over hydraulic brakes, but surge are legal for that weight almost anywhere.
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Thu May 20, 2021 8:30 pm    Post subject: Reply with quote
Use to tow it with our 6 cyl no problem. If you know where your going tow it without too much gas or water and that will help a little.
pelkie123
PostPosted: Thu May 20, 2021 11:43 pm    Post subject: Reply with quote
Thanks for replies. Good to know the 22 and tandem trailer is not too much.
( p.s. - I meant "CD" for C-Dory, not SD. )
PostPosted: Fri May 21, 2021 12:44 pm    Post subject: Reply with quote
I tow my 22 with a 4ltr. 6 cyl Nissan Pathfinder (rated for 6k#). Tows it just fine.
The towing weight of my boat on a tandem Al trailer is ~4400#
Nancy and Bud
City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
PostPosted: Fri May 21, 2021 4:07 pm    Post subject: Reply with quote
I tow with a Subaru Ascent, 2.4L. No problem
"C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine
Page generation time: 0.0422s (PHP: 42% - SQL: 58%) - SQL queries: 19 - GZIP disabled - Debug on
