Keweenaw2018
Joined: 27 Aug 2020 Posts: 31 City/Region: Upper Peninsula
Vessel Name: Norppa
Photos: Keweenaw2018
Posted: Mon May 10, 2021 3:15 pm Post subject: Best prop for efficiency? |
Looking to maximize fuel efficiency. I'm a bit out of my depth here RE props, but the facts that I know are as follows:
Boat: 2000 Cruiser 22
OB: 2021 Honda 100 hp
Water: Fresh, cold
Alt: 600' > sea level, so basically SL
Trim tabs: (not sure if relevant) but yes
Desired outcome: fuel efficiency / range
What's the best prop for me? _________________ Cheers,
-Hunter |
Posted: Mon May 10, 2021 3:48 pm Post subject: |
What is the WOT RPM WITH THE PROP YOU HAVE NOW? What is the speed you get with at WOT?
Generally a 3 blade SS prop in 15" pitch will be best with the Honda 90=100. If you keep the boat very hight, you might get away with 17" prop.
Aluminum props are cheaper, but flex more and will be more easily damaged than a SS prop. On the other hand, a hard strike and SS prop may carry enough impact to damage the lower unit gears. I generally run a SS prop. and the back up prop (all boats should have back up props--and the tools to change the prop, if damaged. I also carry extra cotter pins, Castle nuts, and thrust washer--just in case.... _________________ Bob Austin
Joined: 27 Oct 2012 Posts: 3387 City/Region: SW Michigan
Posted: Mon May 10, 2021 6:39 pm Post subject: |
thataway wrote: | What is the WOT RPM WITH THE PROP YOU HAVE NOW? What is the speed you get with at WOT?
Aluminum props are cheaper, but flex more and will be more easily damaged than a SS prop. On the other hand, a hard strike and SS prop may carry enough impact to damage the lower unit gears. I generally run a SS prop. and the back up prop (all boats should have back up props--and the tools to change the prop, if damaged. I also carry extra cotter pins, Castle nuts, and thrust washer--just in case.... |
I run an AL prop because IMO a C-Dory is a shallow water boat. Where I boat, sometimes the water is a little shallower than expected and the prop can take a beating. About every other year I just replace it.
I carry a spare prop with me, but not the hardware. I'll have to fix that. |
