Kicker mounted to swim platform?
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Sun May 02, 2021 11:54 am    Post subject: Kicker mounted to swim platform? Reply with quote
Anyone install a kicker to the factory swim step? Boat has dual and I'd like to keep them both. What bracket did you use. There's one I am looking at that can mount to the deck of the swim step.
https://www.boatownersworld.com/panther_swim_platform_bracket_550030.html
davidJ
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
Photos: davidJ
PostPosted: Sun May 02, 2021 8:00 pm    Post subject: Reply with quote
Our CD 19 came with 2 swim platforms, one with a ladder and the other with a kicker bracket mounted to it . It was a Sea Dog brand but I don't think they make them any more, but you can find similar units at All boat products or Adventure Marine listed under swim step motor mounts. Ours works good, but the height is not adjustable, so check your motor shaft length. You may have your prop dragging in the water when up or coming out of the water when running into waves when down. good luck.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun May 02, 2021 8:30 pm    Post subject: Reply with quote
Dessert First mounted one of these on the swim platform using green removable stainless pull pins. The job was very well done as the drilled holes were oversized and filled with epoxy and the pins had fender washers. https://www.walmart.com/ip/Garelick-Mount-Platform-Horizontal-71078-01/32921438
Steve Baum
Homeport of Portsmouth, VA
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Sun May 02, 2021 9:04 pm    Post subject: Reply with quote
Perfect. Thanks. Found the site and saved the page.
Page generation time: 0.0398s (PHP: 40% - SQL: 60%) - SQL queries: 17 - GZIP disabled - Debug on
