Is it time to replace my anode?
C-Wolfe
Vessel Name: Valhalla
Photos: C-Wolfe
PostPosted: Fri Apr 09, 2021 7:49 pm    Post subject: Is it time to replace my anode? Reply with quote
I have picture of them in my photo album, for some raison I can’t attach to this post. It’s either something is not working or most likely it’s me that can’t figured out how top do this even though I have done it in the past.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Apr 09, 2021 8:47 pm    Post subject: Re: Is it time to replace my anode? Reply with quote
I would just because its off, also the one under the mount below the trim motor and the internal ones. Thumbs Up
PostPosted: Fri Apr 09, 2021 8:49 pm    Post subject: Reply with quote
Hope that helps. Lots of variations in computers, browsers and the ways the stars are lined up tonight. Basic with an HP laptop on Windows10, find the image you want in your album, Right click on it then left click to get a popup menu, that will have an option to "copy the image address". left click to do that, then go to the thread and right click to bring up another menu. Choose "paste", then highlight that address and go to the "Image" button in the row of buttons above the thread posting box, click there and should have an "img" at the front and "img/" after the address line. Click "Submitt" and then go to the "Preview" at the bottom of the page and click preview to see what you have.
See? Easy Peasy. (After a hundred times Rolling Eyes
I think the formula for replacement is when it has lost 2/3 of it's weight. Can't always tell by looks.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Fri Apr 09, 2021 9:27 pm    Post subject: Reply with quote
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Fri Apr 09, 2021 9:28 pm    Post subject: Reply with quote
C-Wolfe,
Standard best practice for marine industry, including military vessels is to replace at 50% or less. Don’t forget that most outboard water cooled manifolds, also have zinc anodes to replace at the same general percentage.
Steve Baum
Homeport of Portsmouth, VA
C-Wolfe
Photos: C-Wolfe
PostPosted: Fri Apr 09, 2021 9:45 pm    Post subject: Reply with quote
Thanks Harvey, that look very simple... except, I use a Mac.
Thanks anyway, I’ll work on my picture posting skill soon.
C-Wolfe
Photos: C-Wolfe
PostPosted: Fri Apr 09, 2021 9:53 pm    Post subject: Reply with quote
srbaum wrote:
C-Wolfe,
Is it by weight? (as per Harvey’s suggestion). I have seen some that were mostly gone, mine look rough but not much material missing. Might be a silly question but how can I figured out the weight of it new? Or will it be just easier to follow Tsturm advice and replace just because it’s off Wink
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sat Apr 10, 2021 6:54 am    Post subject: Reply with quote
C-Wolfe,
Generally, the 50% guideline, is based upon a visual inspection. Additionally, sometimes zincs may look good, but are literally dust, sorta kept looking okay, by the other metals used in the anode, aside from the actual zinc alloy.
You can tap on a zinc with a small hammer, if it is questionable.
On our outboards, the zincs are good insurance, so if questionable, just replace it. If the manifold is off, I replace the internal ones, regardless of how much remains, just because pulling the manifold is a bigger job then a lot of the other general outboard maintenance.
DayBreak
City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
PostPosted: Sat Apr 10, 2021 12:57 pm    Post subject: Reply with quote
http://www.c-brats.com/modules.php?set_albumName=album2856&id=Internal_Anodes&op=modload&name=gallery&file=index&include=view_photo.php
Link above shows our old internal anodes.
After only 260 hours of running time our internal anodes were due to be replaced. The location and number of internal anodes differ with each outboard motor manufacturer. Think about the ones you can't see.
Gary F
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sat Apr 10, 2021 1:13 pm    Post subject: Reply with quote
That anode is fine in my book. It's doing what it is supposed to do.
Page generation time: 0.0438s (PHP: 68% - SQL: 32%) - SQL queries: 23 - GZIP disabled - Debug on
