John&Robin
Vessel Name: C-Biscuit (was Wanda Fuca!)
Photos: C-Biscuit
Posted: Tue Apr 06, 2021 7:21 pm Post subject: Honda Alternator Fuse Blown |
Hi Brats,
During the engine flush after a couple of days out I noticed the starboard engine wasn't putting out charging voltage. I checked the internal engine fuses and found the alternator fuse was blown. Swapped it for the spare and it's working again. Does anyone have suggestions on what to look for that might have caused this? We've got twin Honda 40's wired to a 1-2-Both-Off battery switch and two 12V batteries. Any suggestions appreciated!
John _________________ John and Robin |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Tue Apr 06, 2021 8:08 pm Post subject: |
There was a short somewhere that blew the fuse - maybe. Nobody will be able to tell you where with much certainty as that is complicated and will depend on boat electronics configuration. But, I doubt it is your battery switch that caused it. I can't think of any known smoking gun trouble areas on the honda 40/50 motors that had electrical problems. However, running 2 outboards on 2 batteries connected together on "both" is never a good idea. In fact, I'd never do it because the regulators can and will fail - hope you're not doing that. So, this was a really long way of saying I have no idea.....lol..... |
John&Robin
Photos: C-Biscuit
Posted: Tue Apr 06, 2021 9:20 pm Post subject: |
Thanks for the suggestion, and yikes, the advice! I always run on BOTH, thinking I'm charging both and that would be a good thing...
Two batteries, one switch, two engines, how should they be set up (if I can lean on your good will and expertise!)?
John |
T.R. Bauer
Posted: Wed Apr 07, 2021 12:18 am Post subject: |
Each engine will charge each battery just fine on it's own if they are wired individually. There is not a need to go to "both" unless there is some emergency and one engine will not start. And, if you only have 2 batteries, putting the switch to "both" can cause each regulator to go into a hyper mode of sorts with them switching like crazy and then they fry themselves - eventually. Lots of folks have had this happen. That may or may not have caused your fuse to blow. It's really hard to tell. Do you have a 3rd battery too? |
clayhubler
Joined: 03 Aug 2019 Posts: 377 City/Region: La Center
Vessel Name: Hammerhead
Photos: Merlin and Hammerhead
Posted: Wed Apr 07, 2021 2:56 am Post subject: |
So two engines on one battery is no good? My boat is like that, but if it is a time bomb then I'll have to make some changes. _________________ Clay
Hammerhead
2003 22’ Cruiser
Merlin
1986 26’ Cruiser |
T.R. Bauer
Posted: Wed Apr 07, 2021 10:13 am Post subject: |
That's what the people at the shop said who are supposed to know when I added my 3rd battery, because I wanted to tie both hondas together on a battery and use the other spot for the house so I'd only have 2 to deal with. The parts/tech rep said don't do that, gave the reason, and now I have 2 lead acid starting batteries and 1 lifepo4 house battery. I strongly suspect that many people have gotten away with it. |
John&Robin
Photos: C-Biscuit
Posted: Wed Apr 07, 2021 10:58 am Post subject: |
Thanks TR,
We have two deep cycle batteries, lead acid, so I've randomly designated one as house, other for starting when we cruise. I'm on the hunt for a wiring diagram for twins with two batteries as I'm not excited about installing a third but don't want to burn up regulators! Hope you're thawed out up there and getting time on the water.
John |
clayhubler
Posted: Wed Apr 07, 2021 1:48 pm Post subject: |
Thank you for this info TR Bauer,
When I got the boat it had three batteries which are new and in good condition. All were tied together into one huge rats nest and so I dedicated two to the house bank and one to the engines and didn't have any troubles, so far... I don't know if I can make room for another start battery and it seems a little silly to have 4 batteries on a CD22.
I only charge my batteries with the engines (or an external charger while in the carport), and I was wary of mixing battery types. Have you had any issues in this regard, or do you charge the lifepo4 with a charger and/or solar?
Sorry to hijack the thread like this but this is good info,
Thanks |
Joined: 07 Nov 2003 Posts: 7938 City/Region: marysville
C-Wolfe
Joined: 16 Sep 2020 Posts: 343 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Wed Apr 07, 2021 2:17 pm Post subject: |
I use a BEP switch cluster with 2 batteries, one for each engine, and they each have their own on/off switch. I have the off-1-2-both and can decide which on I will be using for my house battery. each battery have its own meter inside for monitoring. I try to upload the diagram but it didn’t work. |
C-Wolfe
Photos: C-Wolfe
Posted: Wed Apr 07, 2021 2:51 pm Post subject: |
Ran out of time for editing, parts number is 715-S if you want to look up the diagram. |
Joined: 02 Nov 2003 Posts: 21524 City/Region: Pensacola
Posted: Wed Apr 07, 2021 3:33 pm Post subject: |
I would also like to know how you are charging the LiFePO4 battery. What have you done to prevent it from ever being attached directly to one of the FLA batteries? _________________ Bob Austin
John&Robin
Photos: C-Biscuit
Posted: Wed Apr 07, 2021 4:03 pm Post subject: |
C-Wolfe,
Thanks for the info, it looks like the solution. Does the 715-S also combine the two batteries, or do you have a separate 1-2-both switch? |
C-Wolfe
Photos: C-Wolfe
Posted: Wed Apr 07, 2021 4:25 pm Post subject: |
John&Robin wrote: | C-Wolfe,
The 715-S has 3 different switch. 2 battery/engine switch (port and starboard ) and a main off-1-2-both (combine). If one battery is dead you can combine to start . |
T.R. Bauer
Posted: Wed Apr 07, 2021 9:47 pm Post subject: |
Probably the wrong way by somebody. I was instructed that as long as you don't ever run on "all" they are mechanically disconnected from each other. And the volt meter says it is true. So basically, when I set my perko over to the lifepo4 battery, it is just powering the house. Then, if I switch over the starting battery, it isn't tied to lifepo4, except for the moment in time you pass through "all" on the switch, which is about 1/4 a second and supposed to be safe. The bad part is, the only way to charge the lifepo4 with the outboard is on both, which can never happen since you can't run these batteries in parallel, so that kind of sucks. But, I don't do much more than weekends, don't have much power demand, and the lifepo4 never gets that low (so the math says) that I have run into trouble with that. It gets charged by a small charger lifepo4 charger at camp, the dock, or at home. It's not ideal by any means. Is there a way to make it ideal? |
