Swim step outboard motor bracket
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Thu Jun 03, 2021 11:36 am    Post subject: Swim step outboard motor bracket Reply with quote
The new 2007 has two swim steps installed. Instead of removing one to add a kicker I was thinking of a swim step bracket. Anyone know the water depth from the swim platform to the water? Need to figure out if a long shaft is going to be needed. Does anyone have a kicker mounted to the swim step? Any issues? Push comes to shove might have to remove one.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Thu Jun 03, 2021 12:10 pm    Post subject: Reply with quote
Dessert First mounted one of these on the swim platform using green removable stainless pull pins. The job was very well done as the drilled holes were oversized and filled with epoxy and the pins had fender washers. https://www.walmart.com/ip/Garelick-Mount-Platform-Horizontal-71078-01/32921438
With this arrangement, a short shaft outboard world be perfect.
Steve Baum
Homeport of Portsmouth, VA
Page generation time: 0.0777s (PHP: 20% - SQL: 80%) - SQL queries: 20 - GZIP disabled - Debug on
