New Honda BF90 Steering Stiff
fidalgoisland
Vessel Name: Sea Critter
Photos: Sea Critter
PostPosted: Tue Mar 02, 2021 4:06 pm    Post subject: New Honda BF90 Steering Stiff Reply with quote
Post this as a new topic.
I have been going through the break in process on my new Honda motors and have a question. Compared to the Suzuki I replace the steering on the new BF90 is very stiff. Is this normal at first and/or is there an adjustment? Thanks.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Tue Mar 02, 2021 4:46 pm    Post subject: Reply with quote
Disconnect the steering cylinder from the motor and see if it is still stiff. After that you should be able to move the motor by itself and see how that feels.
Jody Kidd
KE7WNG
Northern, Utah
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Tue Mar 02, 2021 9:45 pm    Post subject: Re: New Honda BF90 Steering Stiff Reply with quote
If you have hyd. steering Honda & Suz. require different brackets for cylinder attachment. Thumbs Up
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Mar 02, 2021 10:03 pm    Post subject: Reply with quote
It should steer with ease. Something is not right and you need to figure it out as parts could break. I have lost steering before and it is not that much fun.
PostPosted: Wed Mar 03, 2021 3:22 pm    Post subject: Reply with quote
is it stiff in both directions or just one? if just one you may need to adjust the rudder on the out board. Often over looked detail.
Also see if the shop greased the main hub (?) its a zerk fitting that greases the main shaft that the motor sits on.
Page generation time: 0.0412s (PHP: 40% - SQL: 60%) - SQL queries: 22 - GZIP disabled - Debug on
