ATPNW
Vessel Name: Fellowship
Photos: Fellowship
Posted: Wed Feb 24, 2021 6:15 pm Post subject: Mounting Downrigger Hardware Advice |
Hello,
We recently purchased a Caper Cruiser 23', and are trying to get it prepped for the upcoming fishing season. We purchased Burnewiin Mounts to place on the gunnels. My questions are:
1. When drilling the 4 screw holes for the gunnel mount. Should I be using the technique where I drill a larger hole, fill with epoxy, and then drilling the correct size hole for the hardware?
2. When using the hole saw, there will obviously be a hole left in the gunnel. Should I be applying silicone to the hole that is left before inserting the mount?
This is our first balsa cored boat, so i am wanting to make sure everything is done correctly the first time.
Thanks, |
Desert Dory
Vessel Name: Desert Dory
Photos: Desert Dory
Posted: Wed Feb 24, 2021 8:50 pm Post subject: Re: Mounting Downrigger Hardware Advice |
ATPNW wrote: | Hello,
Thanks, |
Hey AT,
First of all, congrats on the Cape Cruiser purchase!
1. YES! Over drill, fill with epoxy, re-drill. Although! You'll want to dig out an 1/8th - 1/4 inch of the coring before filling with epoxy.
2. NO! DO NOT USE SILICONE! Do like you are going to do with the bolt holes (dig out the coring) then fill the void with thickened epoxy. You want to thicken the epoxy to basically a peanut butter consistency and pack it in the void between the fiberglass layers. I like to brush a little penetrating/thinned epoxy on the coring before filling with the thickened epoxy. Let it get tacky and fill it with the thickened stuff.
Nice mounts too! |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Wed Feb 24, 2021 9:21 pm Post subject: |
It always is better to over drill and fill with epoxy, but I don't feel that is a hard and fast rule like it is below the waterline. |
robhwa
Joined: 04 Dec 2013 Posts: 295 City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
Posted: Thu Feb 25, 2021 11:15 am Post subject: |
Definitely don't use silicone...it is hard to get off. If you drill, gouge (remove some balsa inside), fill with epoxy, and redrill you won't have a path for water to get into your core.
I use a Dremmel with a cutter wheel the size of the drilled hole, some people put an allen wrench, which also works. The idea is to get a larger solid expoxy area to redrill.
You won't need sealant, but when you do, don't use silicone if you ever want to get it off again, or replace it after it wears. Butyl tape sealant does the job, and is removable. It'll also make a neater job and maybe distribute the weight a little more evenly.
Do make sure you back the mounting underneath (other side), at a minumum with oversize washers (fender washers), or better yet, get a piece of strap aluminum from a hardware store and cut to distribute the weight over a greater area than the bracket covers above. Underneath will be where your greatest stress will be, and that stress can be huge when you hang on something. |
robhwa
Posted: Thu Feb 25, 2021 11:28 am Post subject: |
...since it is available, definitely get the BP620 backing plate as a minimum, but, in my opinion, it might not distribute forces across enough area that it won't stress things. C-Dories are built lighter than most boats (CD22 is 2000 lb for a 22 ft cabin boat). My father's 18 ft crabbing boat was built "like a tank", and weighed more. No cabin either. Maybe the Venture is beefier than a CD22. It is 1000 lbs heavier. There was a standard downrigger mount like this one on my original boat, and the fiberglass had "star" cracks from the stress. I'd probably make a custom part that is 2 or 3 times the length of the one you purchased if I could to better distribute the forces from your downrigger. |
ATPNW
Photos: Fellowship
Posted: Thu Feb 25, 2021 1:02 pm Post subject: |
Thank you all for the replies. A couple follow up questions if I could ask:
When filling the void in the gunnel with epoxy what do I put below/under the gunnel to keep the epoxy from running through? Would duct tape do the trick?
Also I did purchase the backing plate. But if I were to make a larger one myself out of 316 stainless steel sheet. What sort of tool would I use to cut it?
I've never done much with metal before but assuming it would just be a trace and cut?
Thanks, |
davidJ
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
Photos: davidJ
Posted: Thu Feb 25, 2021 1:40 pm Post subject: |
On my CD 19, there is a 3" plastic pipe that runs about an inch under the gunnel on the starboard side, it holds your engine controls and wiring. If your 23 has one your mounts will not fit. You can check under your battery hatch to see what you have one.
Mounts for downriggers and pot pullers need to be bolted down, so you will have to cut an access hole on the inside of the hull thru the liner and dig out the styrofoam to put the nuts and washers on. You can get access covers to cover the holes. On my 19 the gunnels are wider, so I was able to work around the pipe to install Scotty base plates and also a pot puller bracket. Your mounts look really nice, but I wouldn't want to cut a 2" hole on top of my gunnels
Over drilling and filling with epoxy is for under water application, use a good calk or bedding compound, that's what they do on sail boats, and they have a lot of brackets on their decks and your brackets are going to be staying on forever. You can check the photo albums to see what people are doing on the 22's and 23's. |
Joined: 27 Oct 2012 Posts: 3565 City/Region: SW Michigan
Posted: Thu Feb 25, 2021 2:34 pm Post subject: |
ATPNW wrote: | ...When filling the void in the gunnel with epoxy what do I put below/under the gunnel to keep the epoxy from running through? Would duct tape do the trick?... |
I just use blue painters tape. |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Thu Feb 25, 2021 3:10 pm Post subject: |
Just my two cents. Over drill and fill as stated above. Use thru bolts and a backing plate. Steel is good but rust and alum is alright but bends if not thick enough. I like to use a think piece of star board. Does not rot rust swell or shrink. Easy to work with hand tools. I would also use 4200 to create a seal around the mounts. The back fill will keep water out of your core but you dont want water running down the inside and sitting. Also see where the water that is going to go down the 2 inch mount holes when your not using the down riggers. Is it going to run to the bilge or to your batteries? On to you control cables? Know where that water is going to. When you cut your 2 inch hole make sure its really tight to the pole part of the mount. If it can rock back and forth a 1/4 inch that is a lot of room for the side / down pressure of the down rigger to move. i would go with a solid mount for the downriggers my self.
I just read your post and you said burnewin mounts and I assumed for downriggers. If these are just for rod holders then a backing plate is not needed nor are thru bolts. I would thru bolt it but thats just me and knowing how hard I am on stuff. But if just for rods or a bbq or table then the screws will work. Still over drill and fill. _________________ Thomas J Elliott
Posted: Thu Feb 25, 2021 3:16 pm Post subject: |
Quote: | Definitely don't use silicone...it is hard to get off. | depends on what you use. If he over drills and fills with epoxy then I would use a clear bathroom silicone just to keep water from getting in and sitting under the mounts. remember 4200 is when you may one day want to remove it, 5200 is for when you what what ever to still be attached after a nuke strike, the last coming, asteroid strike and a visit by your mil and need to show the devil you did it right. |
robhwa
Posted: Thu Feb 25, 2021 3:34 pm Post subject: |
ATPNW wrote: | Thank you all for the replies. A couple follow up questions if I could ask:
Thanks, |
You can use aluminum stock, available in different thicknesses and widths, and easily worked with drill, jigsaw (with right blades), and cutoff saw (carbide blades are best). You can try first with the supplied mounting plate, and see if you think the support is enough. If it is, no need to fabricate something else. I used two pieces, one on either side, which could work for you. You can also have any machinist worth their weight in salt make you one. Use your judgement...that plate wouldn't have been enough for mine. |
ATPNW
Photos: Fellowship
Posted: Thu Feb 25, 2021 6:38 pm Post subject: |
Quote: | Is it going to run to the bilge or to your batteries?...
I just read your post and you said burnewin mounts and I assumed for downriggers. If these are just for rod holders then a backing plate is not needed nor are thru bolts. I would thru bolt it but thats just me and knowing how hard I am on stuff. But if just for rods or a bbq or table then the screws will work. Still over drill and fill. |
I believe it goes gunnel straight into the cockpit, but ill be sure to check. Yes we plan to use the mounts to attach both downriggers and rod holders. Our plan is to have the boat for the next 20 years or so (only 30 now), so we will go the epoxy route. My experience with epoxy is limited, and I've only ever really used West System Six10. Would that be sufficient here or should I be going with the 105 resin and 205/206 hardeners?
I appreciate all the input and will be sure to document my progress for others future use. |
davidJ
Photos: davidJ
Posted: Sat Feb 27, 2021 3:02 pm Post subject: |
Are you aware that all of the 100+. bolts and screws that are attaching things to your deck and cabin are embedded in calk. It doesn't make much sense to over drill, fill with epoxy and re-drill your bolt holes when the cleat sitting next to your mount is embedded in calk. But I still would seal the edge of the big hole with resin, but I still don't like putting a big 2" hole in the gunnel. I hope you can attach a pot puller to your mounting bracket most of us up in the San Juans do crabbing shrimping and salmon fishing, and usually we will get at least 10 crab and about 80 shrimp for every salmon and some times we can crab, shrimp and try to catch salmon all on the same day, but it doesn't happen very often. Your down rigger should have a pole holder mounted on it so you can set your 2nd mount far enough away from the first mount so you can pull pots over the side between your downrigger and your pot puller. You can check out my photo album for set up ideas. good luck. |
