markwright C-Dory Factory Representative
Joined: 11 May 2013 Posts: 109 City/Region: Bellingham/NW
Photos: C-Dory Factory
srbaum
Joined: 30 Aug 2010 Posts: 887 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Wed Dec 09, 2020 7:23 pm Post subject: |
Mark,
The link to the story does not work. _________________ Steve Baum
Homeport of Portsmouth, VA
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Wed Dec 09, 2020 8:46 pm Post subject: |
Good evening, Mark. Thanks for the story!
I think I got your links and albums all in line with what you were after. I renamed the sub album containing the story pictures as 23 Venture Story and changed the link in your original post on the story (this one) to go to the right spot.
If that all seems to be working for you I can delete this thread so the discussion - along with the Oohs & Ahs - will all be in one spot. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Posted: Wed Dec 09, 2020 9:32 pm Post subject: |
Quote: | Attention!
The album or photo that you were attempting to view either does not exist, or requires user privileges that you do not possess. Log in and try again. |
_________________ Bob Austin
Posted: Wed Dec 09, 2020 11:18 pm Post subject: |
Hey Tyboo Mike, I just tried your link, which took me back to the original story thread, and then linked on Mark's photo link, and it smoothly took me to the Venture story. So I think you did a great job in fixing it! I'm all for deleting this thread now, if the OP is happy with what you did. Colby |
Posted: Wed Dec 09, 2020 11:31 pm Post subject: |
IGNORE ME, I USED THE ORIGINAL LINK, NOT THE SHORT LINK. iT WORKED LIKE COLBY SAID.
NEED TO TAKE OUT MARKS ORIGINAL LONG LINK.
HARVEY
SLEEPYC
Posted: Thu Dec 10, 2020 5:45 pm Post subject: Thanks for you Help! Brats helping a Big Brat! |
Thanks a lot guys. I am still a novice with the C-Brat photo platform. Clearly it dupes me! I will keep adding pictures to the 23 Venture Story Link as I can!
Appreciate all the help! |
Posted: Fri Dec 11, 2020 1:47 am Post subject: |
Nice, Mark, It is working. Looks great.
Thanks to Tyboo too.
SleepyC
Knipet
Joined: 11 Nov 2018 Posts: 262 City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
Posted: Wed Dec 16, 2020 5:18 pm Post subject: |
Hey Mark,
Is that by chance the Venture 23 that is being build for me? Marty at Master Marine just sent me some photos of my build. Is this one and the same?
- Steve Pettyjohn _________________ Steve & Joanie
2021 Venture 23 "Pan-A-C'ya
Formerly C-Sharp - 2006 22 Cruiser |
Posted: Wed Dec 16, 2020 9:56 pm Post subject: |
Mark,
Thank you for annotating the photos. Boat looks great!
Are you doing the lamination with the mold on its side?
Are you using resin infusion technology?
Are you using vacuum bagging when the core and inner layer is applied?
For those who do not know, C Dory is one of the few companies who keep the hull and deck in the molds when the hull to deck joint is glassed together. This makes the strongest hull and hull to deck joint. Other builders may use "glue" adhesives, pop rivets or an "H" section of aluminum to attach the hull to the deck--and it is done out of the molds. |
DayBreak
Joined: 16 Jul 2017 Posts: 863 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Thu Dec 17, 2020 12:40 am Post subject: |
I did not know this Bob. Credit goes to NMI because this adds labor costs to the build. With the glass strengthening this joint it would also reduce flexing which causes leaks. Makes me appreciate my C-Dory even more. _________________ Gary F
DayBreak, 23 Venture, 2018 - present |
jkidd
Joined: 23 Oct 2006 Posts: 1628 City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
Posted: Thu Dec 17, 2020 10:24 am Post subject: |
Mark thanks for the story the picture where the rear deck is being glassed in looks like that would be an air tight compartment is there any structure supports under that? Is the 22 done the same way? _________________ Jody Kidd
KE7WNG
Northern, Utah
