CC Rider
Joined: 19 Nov 2013 Posts: 164 City/Region: Tsawwassen
Vessel Name: CC Rider
Photos: CC Rider
Posted: Fri Feb 12, 2021 4:27 pm Post subject: |
WOW, weighs more than my trailer and half of my boat.
SleepyC
CC Rider
Photos: CC Rider
Posted: Fri Feb 12, 2021 5:26 pm Post subject: |
Yeah, at 1260 lbs , my guess is it wouldn't be a good choice to re-power a CD16!  |
Robert H. Wilkinson
Joined: 26 Jan 2011 Posts: 1276 City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
Posted: Fri Feb 12, 2021 5:49 pm Post subject: |
Pod steering on an outboard - that is neat!
Just to compare - The Seven Marine 627Sv weighed in around the 1,000pd. mark and the price tag in March 2020 was around $100,000.00. It used a GM 6.2L mounted horizontally. Seven Marine was acquired by Volvo in 2017. Last month Jan. 2021 - it was announced that they were no longer going to be produced.
Interesting innovations,
Rob _________________ Talk to me and I will listen-- but if its not about boats or fishing all I will hear is bla,bla,bla,yada,yada,zzzzzzzz |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Fri Feb 12, 2021 9:45 pm Post subject: |
It really is an innovative outboard. And, if you do the math, it has a fabulous power to weight ratio. Think about it.....600 hp to 1200 pounds is how many hp to 400 pounds? Which happens to be the weight on the back of most 22s.....I'll give you a hint....200 hp..... |
Posted: Fri Feb 12, 2021 9:56 pm Post subject: |
T.R. Bauer wrote: | It really is an innovative outboard. And, if you do the math, it has a fabulous power to weight ratio. Think about it.....600 hp to 1200 pounds is how many hp to 400 pounds? Which happens to be the weight on the back of most 22s.....I'll give you a hint....200 hp..... |
Ah yeah, Zoooom Zooooom.
SleepyC
Robert H. Wilkinson
Photos: Romakeme IV
Posted: Sat Feb 13, 2021 9:07 am Post subject: |
T.R. Bauer wrote: | it has a fabulous power to weight ratio. |
Not sure what block Merc is using but 7 Marine used the Cadillac 6.2 L Aluminum block. The 627hp model was supercharged. For $100grand I wonder how many hours you would get from an aluminum supercharged block? Some battlewagons swapped out triple 350hp outboards for 2 - 627Sv's resulting in more hp. and less weight.
Chatter on the web suggests 2 reasons for the demise - a very tiny market for this product and dealers/qualified service being few/far between. With Merc's larger dealer network in North America and the novelty of the pod type drive and 2 speed tranny maybe it will fly. Apparently the 2 speed is possible because of the 600ft.pds. of torque it produces at only 3,000rpm. Some suggest using a variable pitch prop would have been better. 7 Marine lasted about 10 years - so time will tell with the Merc.
Rob |
T.R. Bauer
Posted: Sat Feb 13, 2021 12:42 pm Post subject: |
Merc makes their own blocks specifically for marine usage now. This one does not have turbo, isn't supercharged, and runs on 87 octane. I think it will have great longevity and be dependable. Whenever you start throwing forced induction on gas motors and then working them hard like you do in a boat, it's not the best scenario for lasting a long time. Oh....and it's got huge displacement at almost 8 liters! |
Robert H. Wilkinson
Photos: Romakeme IV
Posted: Sat Feb 13, 2021 3:05 pm Post subject: |
T.R. - relying on GM for blocks kind of deep sixed a lot of marine power plants. Even screwed up their truck power choices. Friend of mine always had a GM dually with a 454 for hauling boats - he hated diesels. Last time I saw him he had a new diesel dually because he said that was the only thing he could get with enough torque to pull larger boats(owns a marina).
8 liters - that would help explain the torque in the lower rpm range. Totally agree with you re. the forced induction shortening engine life. Since loosing some of the big blocks manufacturers have resorted to squeezing more and more power from smaller disp. blocks. Forced induction > more hp > higher rpm > shorter stroke > less torque and less hours. There was a reason why tweekers used to stroke and bore engines.
Sounds like maybe Merc built this one to last, as long as that swiveling pod holds up in the salt water. A lot of the battlewagons that want this type of power are offshore salt water fishers, cruisers and speed boats.
Rob |
