dinghy davit lift
dreamer*69
City/Region: DULUTH
State or Province: MN
PostPosted: Tue Feb 09, 2021 6:44 pm    Post subject: dinghy davit lift Reply with quote
I'm looking to install a dinghy davit lift for a 80 - 100 pound inflatable RIB dinghy 8' to 10' long on a CD 22 cruiser. I've searched most of the posts but could still use any suggestions or advice. Thanks.
dreamer
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Wed Feb 10, 2021 12:07 am    Post subject: Reply with quote
Here is one from Dr. Bob, our resident expert on all things C-Dory and boating in general:
http://www.c-brats.com/viewtopic.php?t=21520
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Wed Feb 10, 2021 11:42 am    Post subject: Reply with quote
Dreamer:
You have not commented on my post on your earlier thread on the weight and construction of the Del Mar 9.5' dinghy. It does not appear to be a RIB. If it is an RIB, then hoisting requirements are going to be different as are cradle arrangements to prevent damage to the top of the cabin if carried right side up. If not carried right side up, the how are you going to flip it? (It is possible, but with that big a dinghy on a 22, may be difficult.)
Please respond to the questions.
The Garheur Davit is what most of us use. It is in the $400 range, and get the 2" diameter pipe, The long arm, and at least 12 to 18" longer lower section that the standard.
In my photo albums: There is a dedicated album to the dinghy lift which was up dated only a few weeks ago. There are also other threads recently involving the davit. There are comments under each photo. The dinghy pictured is 9'6" long. Thisaway, had a Radar on a strut forward. Thataway has the radar on the top of a tall Radar Arch, so the tubes of the 68# air floor inflatable fit under the arch. You will be better served with an air floor, rather than wood'/aluminum floor in the inflatable dinghy.
One of the key features is getting the spreader bar of the correct size and construction--as well as placement of the "D" ring patches to be at the precise balance point. The D ring PVC patches on Amazon do very well, when applied with the HH 66 PVC adhesive. My concern is that at 115# that you are going to need a considerably stronger spreader bar. Mine is made of 1" square aluminum stock tubing, with a dowel which just barely fits epoxied into the center, then cariberners suspended from eye bolts to secure the spreader bar to the dinghy. For 115# you are going to have to design a beefier spreader bar. Perhaps of SS square tubing 1 1/4 to 1 1/2" diameter. Tubing might also work. You will have to make a jigs or hold the tubing in a machinists device when you use your drill press to drill the holes to be sure that both the center attachment point and the outer eye bolts are in alignment. I was able to find a galvanized steel spreader bar which was 24" long, and would work--but will require you to have a proper size carabiner or suitable link to secure to the D rings. This spreader bar is far more robust than the aluminum one I use. It is also considerably heavier. Also you will have to protect the end of this galvanized bar to be sure it does not damage the fabric of the inflatable. Caps or even wrapping with duct tape may accomplish this.
Also I am wondering what outboard motor you will be using? If it is a 10HP (as allowed per the web site for that inflatable), it will be in the 80# to 100# range also. If you use that same 9.9 hp outboard as a kicker, then you would put a second station for the hoist in the cockpit so your can transfer it from the kicker mount to the dinghy.
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Wed Feb 10, 2021 2:21 pm    Post subject: Reply with quote
Atkinshoyle.com
dreamer*69
City/Region: DULUTH
PostPosted: Wed Feb 10, 2021 3:38 pm    Post subject: dinghy lift Reply with quote
Bob Austin,
We've already spoken regarding the topic a couple of times via email--Rich (dreamer) Thanks again for all the help/advice. Wink
dreamer*69
City/Region: DULUTH
PostPosted: Wed Feb 10, 2021 6:02 pm    Post subject: dinghy davit lift Reply with quote
Bob,
Great pics, as well! Also, you mention better off with inflatable bottom. Other than weight reduction, will I be compromising much over the aluminum floor's durability (e.g. carrying 65 lb. dog, fishing gear, etc.)? Thanks.
PostPosted: Wed Feb 10, 2021 7:29 pm    Post subject: Reply with quote
jkswor wrote:
Atkinshoyle.com
I have owned several Atkis & Hoyle davit cranes--in the larger sizes to pick up dingoes with 15 to 25 hp outboards and they are a good product. Today the 500# davit with 12 v motor and cable, would cost $4680 plus shipping.
But in the manual davit they get blown away by the price and in my opinion by the quality of the Garhauer Davit. The Atkin & Hoylle 1400 (150# capacity is $1325. The Garheur 150# is $377, less than 1/3 in cost, and all SS, instated of some aluminum castings. The blocks of the Garheur are works of art. Much smoother rolling that any others-plus they are of an adequate size.
Atkins & Hoyle
Garhauer blocks:
Garhauer Davit in horizontal position, a canted up about 20* position is also possible. The lifting line can come thru a block just toward the standing part or across the top of the arm--as it is on the photos on side of the boat, actually hoisting the dinghy.
Both can be customized by length of vertical stand pipe.
Page generation time: 0.057s (PHP: 67% - SQL: 33%) - SQL queries: 24 - GZIP disabled - Debug on
