jkswor
Vessel Name: Missy marie
Posted: Tue Jan 19, 2021 11:28 am Post subject: Anchor locker drain leaking into v berth |
So I found sea water under v berth. I put red coloring in water and poured it into locker then then vacuumed it out through plug used to put foam in .It was red
My boat is a 2007 25 ft cruiser
So I cut a hole in v berth and removed massive amounts of water logged foam. I could feel where the drain hole had nicked the void into the v birth
Any suggestions as to how to repair this drain? |
Posted: Tue Jan 19, 2021 12:02 pm Post subject: |
Epoxy putty. The drain hole in Journey On is drilled to the outside and it's a long way to the locker wall, but it could happen.
Sand the hole out, mix up some epoxy, add thickener, (carbon fluff) stuff it into the hole, use masking tape to hold the epoxy in place.
Boris |
Joined: 27 Oct 2012 Posts: 3599 City/Region: SW Michigan
Posted: Tue Jan 19, 2021 2:28 pm Post subject: |
I epoxied in a plastic tube that connected the hole in the anchor locker to the hole in the hull to prevent water draining into the space under the locker. |
Joined: 02 Nov 2003 Posts: 21536 City/Region: Pensacola
Posted: Tue Jan 19, 2021 6:45 pm Post subject: |
When I have had a similar problem, I filled the bottom of the locker in the following way: First cleaned and sanded out the lowest part of the anchor locker. Then painted epoxy on the side walls down below the hole which was drilled. Next I put a small square of 6 oz cloth saturated with epoxy at the bottom of the anchor locker (area of potential leak). Next filled the rest with peanut butter thick epoxy and smoothed the floor, to allow a sloped drainage to the hole. In the current boat there is a small platform of starboard (triangular shape with 1/2" holes drilled into it, to keep the rode and chain off the bottom of the locker. This allows the rode to dry out.
While you are at all of this--go ahead and remove all of the foam. There is a great storage area up there. You can put hatches, keep the cutouts of fiberglass, or make pkywood lids for this storage area. I keep an extra anchor rode, and storm anchor up forward. There is room for spare lines, extra life jackets etc. In our boat we have the Li batteries on one side and the 2000 Watt viltron inverter charger on t he other side in the after most part of the V berth. _________________ Bob Austin
jkswor
Posted: Sun Jan 24, 2021 12:34 pm Post subject: |
So I put a 26 x 10 hatch in middle of berth area. Where to put additional ones?
On each side top. Or on each side where the pirtapotty goes?
Any photos anywhere showing what folks have done |
C-Wolfe
Joined: 16 Sep 2020 Posts: 343 City/Region: Anchorage
Vessel Name: Valhalla
Photos: C-Wolfe
Posted: Sun Jan 24, 2021 2:28 pm Post subject: |
jkswor wrote: | So I put a 26 x 10 hatch in middle of berth area. Where to put additional ones?
I did some cut out in mine, I’m not sure how to attach photo to post so, just look at my album. |
C-Wolfe
Photos: C-Wolfe
Posted: Sun Jan 24, 2021 2:33 pm Post subject: |
I just realized you have a 25, mine is a 22 so I’m not sure how comparable the 2 are. |
jkswor
Posted: Sun Jan 24, 2021 3:09 pm Post subject: |
25 is pretty much the same. Thanks |
tsturm
Joined: 01 Nov 2003 Posts: 1173 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun Jan 24, 2021 4:56 pm Post subject: |
thataway wrote: | When I have had a similar problem, I filled the bottom of the locker in the following way: First cleaned and sanded out the lowest part of the anchor locker. Then painted epoxy on the side walls down below the hole which was drilled. Next I put a small square of 6 oz cloth saturated with epoxy at the bottom of the anchor locker (area of potential leak). Next filled the rest with peanut butter thick epoxy and smoothed the floor, to allow a sloped drainage to the hole. In the current boat there is a small platform of starboard (triangular shape with 1/2" holes drilled into it, to keep the rode and chain off the bottom of the locker. This allows the rode to dry out.
While you are at all of this--go ahead and remove all of the foam. There is a great storage area up there. You can put hatches, keep the cutouts of fiberglass, or make pkywood lids for this storage area. I keep an extra anchor rode, and storm anchor up forward. There is room for spare lines, extra life jackets etc. In our boat we have the Li batteries on one side and the 2000 Watt viltron inverter charger on t he other side in the after most part of the V berth. |
Exactly what I did on my 2003  |
