No sticking the windows
tparrent
City/Region: Apex
C-Dory Year: 2017
Vessel Name: Tomfoolery
Photos: tparrent (TBD)
PostPosted: Sat Jan 16, 2021 7:51 pm    Post subject: No sticking the windows Reply with quote
My port side window was stuck pretty good a few weeks ago but I eventually got it open with a lot of grunting and groaning. I added some lubricant on the track and all has been fine since then.
The starboard side window used to open fine but is now stuck closed and no amount of pulling is having any effect. The latch is not sticking, it’s the window track that is the problem. Any thoughts on how to get it open? I thought about using a heat gun but worry that may be too hot if too close and not hot enough if too far away - or it may have no effect at all.
One my 22, the windows were difficult to open but never actually stuck closed.
Tom Parrent
2017 TomCat "Tomfoolery"
New Bern NC
Baxter
City/Region: Sheridan
State or Province: WY
Vessel Name: Baxter ll
PostPosted: Sat Jan 16, 2021 8:42 pm    Post subject: Sticky windows Reply with quote
I have used wd40 as temporary solution. It is not a live.
Then after moving used silicone spray to lub.
Helped keep the salt out.
I use heat for lots of stuff but would not for this.
It is annoying problem.
Good luck.
What we do for ourselves stays here, what we do for others goes with us
PostPosted: Sat Jan 16, 2021 8:42 pm    Post subject: Reply with quote
On my 22, I found that shifting the moving part of the window up and down often helped. I also found that not slamming the window closed helps too. Just push them far enough closed for the latch to catch.
Haven't had this problem after thoroughly rinsing the tracks and applying silicon spray.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Sat Jan 16, 2021 8:51 pm    Post subject: Reply with quote
I used to have this problem. Once I got it loose, I power washed the tracks and used silicone spray. No problem since. Got it loose pretty much like Baxter did.
I was amazed how much crap the power wash dredged up out of those tracks! Very Happy
Sandy McKean
Purchased Tosca in 2014
fishingjoe13
City/Region: Loveland
C-Dory Year: 1992
Vessel Name: Fish Frey
PostPosted: Sat Jan 16, 2021 10:26 pm    Post subject: Reply with quote
A small block of wood against the rail on the back end of the window, a rubber mallet, and light tapping and patience. Then I just give mine a shot of silicon spray every couple of months, no more problems.
tomherrick
Guest
PostPosted: Sun Jan 17, 2021 10:26 am    Post subject: Reply with quote
I've had a pretty good rate of success with penetrating oil. Spray the binding surfaces a few times, let it sit, maybe spray a little more, let it sit, then give it shot. A couple of times I've had to wait overnight for the oil to penetrate sufficiently so I didn't cause damage to whatever materials were stuck.
https://en.wikipedia.org/wiki/Penetrating_oil
PostPosted: Sun Jan 17, 2021 11:50 am    Post subject: Reply with quote
If you use any liquid silicone or penetrating oils, and do not totally remove them, salt, algae, and dirt will clog up that felt track again. Be sure and use only dry silicone lubricant. Mary Kate Liiquid rollers is one brand. There are several others.
Use soap and water at first to get it lubricated. Work back and forth if you can.
Before opening clean the track aft as much as you can with soap, water and an old tooth brush. Be sure it is totally clean and dry. spray the dry silicone .Then as you open the window, do the same there. After all dry, spray all around the track the dry silicone.
I use a mini pry bar; end has vinyl sleeve, so no mar. Put it between the inside handle and the frame, and very slowly put pressure on it. If not moving, use a small phenolic or rubber mallet to gently tap forward on the handle and then gently pry aft. Eventually it will move a little and then you can tug on the handle.
If you put too much pressure on the handles--they will eventually detatch--and jump overboard...I have done that a few times. They are not cheap.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Sun Jan 17, 2021 6:39 pm    Post subject: Reply with quote
Each lower felt window track has a covered drain hole which drains down the side of the boat. When debris clogs it, grime has no where to go but build up in the track. Squirt hot water in a syringe or baster down the drains to keep them open. We have a designated Window Track toothbrush, too. I wouldn't want penetrating or any oil going down the track drains. Sticking very often involves some mis-alignment of the long windows in the vertical (not horizontal) plane, though you can't tell where by just looking.
Incidentally, to remove the sliding screens there is K shaped spring running in the TOP screen track. Push the screen frame upward to compress the K and pull it out from the bottom track to remove it.
Add dry silicone, toothbrush, syringe to your list...and a Thermacell for spring. The days are getting longer!
Good Luck!
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
Wayne McCown
City/Region: Rochester
State or Province: NY
Vessel Name: Little Mac
Photos: Little Mac
PostPosted: Sun Jan 17, 2021 8:06 pm    Post subject: Reply with quote
When washing the boat, I spray water up into the external "weep" holes. It is amazing how much gunk/dirt drains out the other holes in the track. I repeat the process, hole by hole, until the water drains out. No sticking since I adopted this approach.
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Sun Jan 17, 2021 9:24 pm    Post subject: Reply with quote
When your boat gets old like mine, you won't have to worry about it any longer. Mine stopped sticking years ago. Of course, they also leak now....
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Mon Jan 18, 2021 11:06 pm    Post subject: Reply with quote
I remember having this problem too! One time I literally couldn't get it budge and I thought I was gonna break the window handle!!
<><><> Jason <><><>
Volant
City/Region: Tallahassee
Vessel Name: Just Enough
Photos: Just Enough
PostPosted: Wed Jan 20, 2021 1:23 pm    Post subject: Reply with quote
A electric dental water pic is a good method for occasional cleaning of the window tracks. It can be more precisely aimed at problem areas and doesn't make a major mess. Also can be done anywhere without a hose.
Just Enough
Standas
City/Region: Poulsbo
C-Dory Year: 2013
Vessel Name: C -Time
Photos: C -Time
PostPosted: Wed Jan 20, 2021 7:12 pm    Post subject: Reply with quote
During my project of repainting and replacing the rubber seals on my windows I replaced the felt track. Slides much easier now.
PostPosted: Thu Jan 21, 2021 3:33 am    Post subject: Reply with quote
Yes, and they even come in a rechargeable battery version. too.
I use the water hose with a really good rinse down after each trip, right into the tracks, after each trip. Then when they are completely dry, a few days later, a couple times a year I give them a good dose of "Dry Roller" (dry silicone spray) and work the windows back and forth a few times with that. Keeps them working nicely.
Page generation time: 0.0715s (PHP: 42% - SQL: 58%) - SQL queries: 30 - GZIP disabled - Debug on
